I’m trying to get LVGL to compile, but keep getting a RAM overflow error. I disabled all the fancy features (anti-aliasing, all the widgets except the label, and most everything else), tried reducing the frame buffer, and everything else I could think of, but it still won’t go! I’m using TFT_eSPI as the driver library, and I have its fancy features disabled as well. The TFT_eSPI demo for my 480x320 screen works without a hitch.
I’m using a BluePill (STM32F103C8T6) with an ILI9486 display from “Kuman” on Amazon. I know it’s not a high-performance board, but all I want to do is show a simple tank level indicator, and I’ve seen some pretty impressive stuff done with a BluePill and LVGL.
I’m using PlatformIO in VSCode with the Arduino method of programming the STM32.
Successfully compile the example code on Github.
I disabled almost everything in LVGL and played with the size of the frame buffer.
Here’s my current stripped-down example code:
#include <Arduino.h>
#include <lvgl.h>
#include <TFT_eSPI.h>
/*Change to your screen resolution*/
static const uint32_t screenWidth = 480;
static const uint32_t screenHeight = 320;
static lv_color_t buf[screenWidth * 10];
/* Display flushing */
void my_disp_flush( lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p )
uint32_t w = ( area->x2 - area->x1 + 1 );
uint32_t h = ( area->y2 - area->y1 + 1 );
tft.startWrite();
tft.setAddrWindow( area->x1, area->y1, w, h );
tft.pushColors( ( uint16_t * )&color_p->full, w * h, true );
tft.endWrite();
lv_disp_flush_ready( disp );
void setup()
tft.begin(); /* TFT init */
tft.setRotation( 3 ); /* Landscape orientation, flipped */
lv_disp_draw_buf_init( &draw_buf, buf, NULL, screenWidth * 10 );
/*Initialize the display*/
/*Change the following line to your display resolution*/
lv_disp_drv_register( &disp_drv );
/* Create simple label */
lv_obj_t *label = lv_label_create( lv_scr_act() );
lv_label_set_text( label, "Hello Arduino! (V8.0.X)" );
lv_obj_align( label, LV_ALIGN_CENTER, 0, 0 );
void loop()
delay( 5 );
My lv_conf file:
* @file lv_conf.h
* Configuration file for v8.0.0-dev
* COPY THIS FILE AS `lv_conf.h` NEXT TO the `lvgl` FOLDER
#ifndef LV_CONF_H
#define LV_CONF_H
/* clang-format off */
#include <stdint.h>
COLOR SETTINGS
/* Color depth: 1 (1 byte per pixel), 8 (RGB332), 16 (RGB565), 32 (ARGB8888) */
#define LV_COLOR_DEPTH 16
/* Swap the 2 bytes of RGB565 color. Useful if the display has a 8 bit interface (e.g. SPI)*/
#define LV_COLOR_16_SWAP 0
/* Enable more complex drawing routines to manage screens transparency.
* Can be used if the UI is above an other layer, e.g. an OSD menu or video player.
* Requires `LV_COLOR_DEPTH = 32` colors and the screen's `bg_opa` should be set to non LV_OPA_COVER value */
#define LV_COLOR_SCREEN_TRANSP 0
/*Images pixels with this color will not be drawn if they are chroma keyed)*/
#define LV_COLOR_CHROMA_KEY lv_color_hex(0x00ff00) /*pure green*/
MEMORY SETTINGS
/* 1: use custom malloc/free, 0: use the built-in `lv_mem_alloc()` and `lv_mem_free()` */
#define LV_MEM_CUSTOM 0
#if LV_MEM_CUSTOM == 0
/* Size of the memory available for `lv_mem_alloc()` in bytes (>= 2kB)*/
# define LV_MEM_SIZE (32U * 1024U) /* [bytes] */
/* Set an address for the memory pool instead of allocating it as a normal array. Can be in external SRAM too. */
# define LV_MEM_ADR 0 /*0: unused*/
#else /*LV_MEM_CUSTOM*/
# define LV_MEM_CUSTOM_INCLUDE <stdlib.h> /*Header for the dynamic memory function*/
# define LV_MEM_CUSTOM_ALLOC malloc
# define LV_MEM_CUSTOM_FREE free
# define LV_MEM_CUSTOM_REALLOC realloc
#endif /*LV_MEM_CUSTOM*/
/* Use the standard `memcpy` and `memset` instead of LVGL's own functions. (Might or might not be faster). */
#define LV_MEMCPY_MEMSET_STD 0
HAL SETTINGS
/* Default display refresh period. LVG will redraw changed ares with this period time */
#define LV_DISP_DEF_REFR_PERIOD 30 /*[ms]*/
/* Input device read period in milliseconds */
#define LV_INDEV_DEF_READ_PERIOD 30 /*[ms]*/
/* Use a custom tick source that tells the elapsed time in milliseconds.
* It removes the need to manually update the tick with `lv_tick_inc()`) */
#define LV_TICK_CUSTOM 1
#if LV_TICK_CUSTOM
#define LV_TICK_CUSTOM_INCLUDE "Arduino.h" /*Header for the system time function*/
#define LV_TICK_CUSTOM_SYS_TIME_EXPR (millis()) /*Expression evaluating to current system time in ms*/
#endif /*LV_TICK_CUSTOM*/
/* Default Dot Per Inch. Used to initialize default sizes such as widgets sized, style paddings.
* (Not so important, you can adjust it to modify default sizes and spaces)*/
#define LV_DPI_DEF 130 /*[px/inch]*/
#define LV_HOR_RES_MAX 480
#define LV_VER_RES_MAX 320
* FEATURE CONFIGURATION
* Drawing
/* Enable complex draw engine.
* Required to draw shadow, gradient, rounded corners, circles, arc, skew lines, image transformations or any masks */
#define LV_DRAW_COMPLEX 0
#if LV_DRAW_COMPLEX != 0
/* Allow buffering some shadow calculation.
* LV_SHADOW_CACHE_SIZE is the max. shadow size to buffer, where shadow size is `shadow_width + radius`
* Caching has LV_SHADOW_CACHE_SIZE^2 RAM cost*/
#define LV_SHADOW_CACHE_SIZE 0
#endif /*LV_DRAW_COMPLEX*/
/* Default image cache size. Image caching keeps the images opened.
* If only the built-in image formats are used there is no real advantage of caching. (I.e. if no new image decoder is added)
* With complex image decoders (e.g. PNG or JPG) caching can save the continuous open/decode of images.
* However the opened images might consume additional RAM.
* 0: to disable caching */
#define LV_IMG_CACHE_DEF_SIZE 0
/* Maximum buffer size to allocate for rotation. Only used if software rotation is enabled in the display driver. */
#define LV_DISP_ROT_MAX_BUF (10*1024)
* GPU
/*Use STM32's DMA2D (aka Chrom Art) GPU*/
#define LV_USE_GPU_STM32_DMA2D 0
#if LV_USE_GPU_STM32_DMA2D
/*Must be defined to include path of CMSIS header of target processor
e.g. "stm32f769xx.h" or "stm32f429xx.h" */
#define LV_GPU_DMA2D_CMSIS_INCLUDE
/* Use NXP's PXP GPU iMX RTxxx platforms */
#define LV_USE_GPU_NXP_PXP 0
#if LV_USE_GPU_NXP_PXP
/*1: Add default bare metal and FreeRTOS interrupt handling routines for PXP (lv_gpu_nxp_pxp_osa.c)
* and call lv_gpu_nxp_pxp_init() automatically during lv_init(). Note that symbol FSL_RTOS_FREE_RTOS
* has to be defined in order to use FreeRTOS OSA, otherwise bare-metal implementation is selected.
*0: lv_gpu_nxp_pxp_init() has to be called manually before lv_init()
#define LV_USE_GPU_NXP_PXP_AUTO_INIT 0
/* Use NXP's VG-Lite GPU iMX RTxxx platforms */
#define LV_USE_GPU_NXP_VG_LITE 0
* Logging
/*Enable the log module*/
#define LV_USE_LOG 0
#if LV_USE_LOG
/* How important log should be added:
* LV_LOG_LEVEL_TRACE A lot of logs to give detailed information
* LV_LOG_LEVEL_INFO Log important events
* LV_LOG_LEVEL_WARN Log if something unwanted happened but didn't cause a problem
* LV_LOG_LEVEL_ERROR Only critical issue, when the system may fail
* LV_LOG_LEVEL_USER Only logs added by the user
* LV_LOG_LEVEL_NONE Do not log anything */
# define LV_LOG_LEVEL LV_LOG_LEVEL_WARN
/* 1: Print the log with 'printf';
* 0: User need to register a callback with `lv_log_register_print_cb()`*/
# define LV_LOG_PRINTF 1
/*Enable/disable LV_LOG_TRACE in modules that produces a huge number of logs */
# define LV_LOG_TRACE_MEM 1
# define LV_LOG_TRACE_TIMER 1
# define LV_LOG_TRACE_INDEV 1
# define LV_LOG_TRACE_DISP_REFR 1
# define LV_LOG_TRACE_EVENT 1
# define LV_LOG_TRACE_SIGNAL 1
# define LV_LOG_TRACE_OBJ_CREATE 1
# define LV_LOG_TRACE_LAYOUT 1
# define LV_LOG_TRACE_ANIM 1
#endif /*LV_USE_LOG*/
* Asserts
/* Enable asserts if an operation is failed or an invalid data is found.
* If LV_USE_LOG is enabled an error message will be printed on failure*/
#define LV_USE_ASSERT_NULL 0 /*Check if the parameter is NULL. (Very fast, recommended) */
#define LV_USE_ASSERT_MALLOC 0 /*Checks is the memory is successfully allocated or no. (Very fast, recommended)*/
#define LV_USE_ASSERT_STYLE 0 /*Check if the styles are properly initialized. (Very fast, recommended)*/
#define LV_USE_ASSERT_MEM_INTEGRITY 0 /*Check the integrity of `lv_mem` after critical operations. (Slow)*/
#define LV_USE_ASSERT_OBJ 0 /*Check the object's type and existence (e.g. not deleted). (Slow) */
/*Add a custom handler when assert happens e.g. to restart the MCU*/
#define LV_ASSERT_HANDLER while(1); /*Halt by default*/
* Others
/*1: Show CPU usage and FPS count in the right bottom corner*/
#define LV_USE_PERF_MONITOR 0
/*1: Show the used memory and the memory fragmentation in the left bottom corner
* Requires LV_MEM_CUSTOM = 0*/
#define LV_USE_MEM_MONITOR 0
/*Change the built in (v)snprintf functions*/
#define LV_SPRINTF_CUSTOM 0
#if LV_SPRINTF_CUSTOM
# define LV_SPRINTF_INCLUDE <stdio.h>
# define lv_snprintf snprintf
# define lv_vsnprintf vsnprintf
#else /*LV_SPRINTF_CUSTOM*/
# define LV_SPRINTF_USE_FLOAT 0
#endif /*LV_SPRINTF_CUSTOM*/
#define LV_USE_USER_DATA 0
#if LV_USE_USER_DATA
typedef void * lv_user_data_t;
/* Garbage Collector settings
* Used if lvgl is binded to higher level language and the memory is managed by that language */
#define LV_ENABLE_GC 0
#if LV_ENABLE_GC != 0
# define LV_GC_INCLUDE "gc.h" /*Include Garbage Collector related things*/
#endif /* LV_ENABLE_GC */
* COMPILER SETTINGS
/* For big endian systems set to 1 */
#define LV_BIG_ENDIAN_SYSTEM 0
/* Define a custom attribute to `lv_tick_inc` function */
#define LV_ATTRIBUTE_TICK_INC
/* Define a custom attribute to `lv_timer_handler` function */
#define LV_ATTRIBUTE_TIMER_HANDLER
/* Define a custom attribute to `lv_disp_flush_ready` function */
/* Required alignment size for buffers */
#define LV_ATTRIBUTE_MEM_ALIGN_SIZE
/*Will be added where memories needs to be aligned (with -Os data might not be aligned to boundary by default).
* E.g. __attribute__((aligned(4)))*/
/* Attribute to mark large constant arrays for example font's bitmaps */
/* Complier prefix for a big array declaration in RAM*/
#define LV_ATTRIBUTE_LARGE_RAM_ARRAY
/* Place performance critical functions into a faster memory (e.g RAM) */
#define LV_ATTRIBUTE_FAST_MEM
/* Prefix variables that are used in GPU accelerated operations, often these need to be placed in RAM sections that are DMA accessible */
#define LV_ATTRIBUTE_DMA
/* Export integer constant to binding. This macro is used with constants in the form of LV_<CONST> that
* should also appear on LVGL binding API such as Micropython.*/
#define LV_EXPORT_CONST_INT(int_value) struct _silence_gcc_warning /*The default value just prevents GCC warning*/
/*Extend the default -32k..32k coordinate range to -4M..4M by using int32_t for coordinates instead of int16_t*/
#define LV_USE_LARGE_COORD 0
* FONT USAGE
/* Montserrat fonts with ASCII range and some symbols using bpp = 4
* https://fonts.google.com/specimen/Montserrat */
#define LV_FONT_MONTSERRAT_8 0
#define LV_FONT_MONTSERRAT_10 0
#define LV_FONT_MONTSERRAT_12 0
#define LV_FONT_MONTSERRAT_14 1
#define LV_FONT_MONTSERRAT_16 0
#define LV_FONT_MONTSERRAT_18 0
#define LV_FONT_MONTSERRAT_20 0
#define LV_FONT_MONTSERRAT_22 0
#define LV_FONT_MONTSERRAT_24 0
#define LV_FONT_MONTSERRAT_26 0
#define LV_FONT_MONTSERRAT_28 0
#define LV_FONT_MONTSERRAT_30 0
#define LV_FONT_MONTSERRAT_32 0
#define LV_FONT_MONTSERRAT_34 0
#define LV_FONT_MONTSERRAT_36 0
#define LV_FONT_MONTSERRAT_38 0
#define LV_FONT_MONTSERRAT_40 0
#define LV_FONT_MONTSERRAT_42 0
#define LV_FONT_MONTSERRAT_44 0
#define LV_FONT_MONTSERRAT_46 0
#define LV_FONT_MONTSERRAT_48 0
/* Demonstrate special features */
#define LV_FONT_MONTSERRAT_12_SUBPX 0
#define LV_FONT_MONTSERRAT_28_COMPRESSED 0 /*bpp = 3*/
#define LV_FONT_DEJAVU_16_PERSIAN_HEBREW 0 /*Hebrew, Arabic, Perisan letters and all their forms*/
#define LV_FONT_SIMSUN_16_CJK 0 /*1000 most common CJK radicals*/
/*Pixel perfect monospace fonts
* http://pelulamu.net/unscii/ */
#define LV_FONT_UNSCII_8 0
#define LV_FONT_UNSCII_16 0
/* Optionally declare custom fonts here.
* You can use these fonts as default font too and they will be available globally.
* E.g. #define LV_FONT_CUSTOM_DECLARE LV_FONT_DECLARE(my_font_1) LV_FONT_DECLARE(my_font_2) */
/*Always set a default font*/
#define LV_FONT_DEFAULT &lv_font_montserrat_14
/* Enable handling large font and/or fonts with a lot of characters.
* The limit depends on the font size, font face and bpp.
* Compiler error will be triggered if a font needs it.*/
#define LV_FONT_FMT_TXT_LARGE 0
/* Enables/disables support for compressed fonts. */
#define LV_USE_FONT_COMPRESSED 0
/* Enable subpixel rendering */
#define LV_USE_FONT_SUBPX 0
#if LV_USE_FONT_SUBPX
/* Set the pixel order of the display. Physical order of RGB channels. Doesn't matter with "normal" fonts.*/
#define LV_FONT_SUBPX_BGR 0 /*0: RGB; 1:BGR order*/
* TEXT SETTINGS
/* Select a character encoding for strings.
* - LV_TXT_ENC_UTF8
* - LV_TXT_ENC_ASCII
#define LV_TXT_BREAK_CHARS " ,.;:-_"
/* If a word is at least this long, will break wherever "prettiest"
* To disable, set to a value <= 0 */
#define LV_TXT_LINE_BREAK_LONG_LEN 0
/* Minimum number of characters in a long word to put on a line before a break.
* Depends on LV_TXT_LINE_BREAK_LONG_LEN. */
#define LV_TXT_LINE_BREAK_LONG_PRE_MIN_LEN 3
/* Minimum number of characters in a long word to put on a line after a break.
/* The control character to use for signalling text recoloring. */
#define LV_TXT_COLOR_CMD "#"
/* Support bidirectional texts. Allows mixing Left-to-Right and Right-to-Left texts.
* The direction will be processed according to the Unicode Bidirectioanl Algorithm:
* https://www.w3.org/International/articles/inline-bidi-markup/uba-basics*/
#define LV_USE_BIDI 0
#if LV_USE_BIDI
/* Set the default direction. Supported values:
* `LV_BIDI_DIR_LTR` Left-to-Right
* `LV_BIDI_DIR_RTL` Right-to-Left
* `LV_BIDI_DIR_AUTO` detect texts base direction */
#define LV_BIDI_BASE_DIR_DEF LV_BIDI_DIR_AUTO
/* Enable Arabic/Persian processing
* In these languages characters should be replaced with an other form based on their position in the text */
* WIDGET USAGE
/* Documentation of the widgets: https://docs.lvgl.io/latest/en/html/widgets/index.html */
#define LV_USE_ARC 0
#define LV_USE_ANIMIMG 0
#define LV_USE_BAR 0
#define LV_USE_BTN 0
#define LV_USE_BTNMATRIX 0
#define LV_USE_CANVAS 0
#define LV_USE_CHECKBOX 0
#define LV_USE_CHART 0
#define LV_USE_DROPDOWN 0 /*Requires: lv_label*/
#define LV_USE_IMG 0 /*Requires: lv_label*/
#define LV_USE_LABEL 1
#if LV_USE_LABEL
# define LV_LABEL_TEXT_SEL 0 /*Enable selecting text of the label */
# define LV_LABEL_LONG_TXT_HINT 0 /*Store some extra info in labels to speed up drawing of very long texts*/
#define LV_USE_LINE 0
#define LV_USE_METER 0
#define LV_USE_ROLLER 0 /*Requires: lv_label*/
#if LV_USE_ROLLER
# define LV_ROLLER_INF_PAGES 7 /*Number of extra "pages" when the roller is infinite*/
#define LV_USE_SLIDER 0 /*Requires: lv_bar*/
#define LV_USE_SWITCH 0
#define LV_USE_TEXTAREA 0 /*Requires: lv_label*/
#if LV_USE_TEXTAREA != 0
# define LV_TEXTAREA_DEF_PWD_SHOW_TIME 1500 /*ms*/
#define LV_USE_TABLE 0
* EXTRA COMPONENTS
* Widgets
#define LV_USE_CALENDAR 0
#if LV_USE_CALENDAR
# define LV_CALENDAR_WEEK_STARTS_MONDAY 0
# if LV_CALENDAR_WEEK_STARTS_MONDAY
# define LV_CALENDAR_DEFAULT_DAY_NAMES {"Mo", "Tu", "We", "Th", "Fr", "Sa", "Su"}
# else
# define LV_CALENDAR_DEFAULT_DAY_NAMES {"Su", "Mo", "Tu", "We", "Th", "Fr", "Sa"}
# endif
# define LV_CALENDAR_DEFAULT_MONTH_NAMES {"January", "February", "March", "April", "May", "June", "July", "August", "September", "October", "November", "December"}
# define LV_USE_CALENDAR_HEADER_ARROW 1
# define LV_USE_CALENDAR_HEADER_DROPDOWN 1
#endif /*LV_USE_CALENDAR*/
#define LV_USE_COLORWHEEL 0
#define LV_USE_IMGBTN 0
#define LV_USE_KEYBOARD 0
#define LV_USE_LED 0
#define LV_USE_LIST 0
#define LV_USE_MSGBOX 0
#define LV_USE_SPINBOX 0
#define LV_USE_SPINNER 0
#define LV_USE_TABVIEW 0
#define LV_USE_TILEVIEW 0
#define LV_USE_WIN 0
* Themes
/* A simple, impressive and very complete theme */
#if LV_USE_THEME_DEFAULT
/* 1: Light mode; 0: Dark mode*/
# define LV_THEME_DEFAULT_PALETTE_LIGHT 0
/* 1: Enable grow on press*/
# define LV_THEME_DEFAULT_GROW 0
/*Default transition time in [ms]*/
# define LV_THEME_DEFAULT_TRANSITON_TIME 80
#endif /*LV_USE_THEME_DEFAULT*/
* Layouts
#define LV_USE_FLEX 0
#define LV_USE_GRID 0
* EXAMPLES
/*Enable the examples to be built with the library*/
#define LV_BUILD_EXAMPLES 0
/*--END OF LV_CONF_H--*/
#endif /*LV_CONF_H*/
And finally, the exact compiler output:
Linking .pio\build\genericSTM32F103C8\firmware.elf
c:/users/jadon/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: .pio/build/genericSTM32F103C8/firmware.elf section `.bss' will not fit in region `RAM'
c:/users/jadon/.platformio/packages/toolchain-gccarmnoneeabi/bin/../lib/gcc/arm-none-eabi/9.2.1/../../../../arm-none-eabi/bin/ld.exe: region `RAM' overflowed by 25392 bytes
I’m really excited about the power of LVGL, but I’m really stuck right now. I could just buy a better processor, but I think I should be able to do a very basic “Hello Arduino” screen with 128k Flash and 20k RAM. Thanks a lot for your help – I really do appreciate it!
Jadon
