ili9341 display not working using driver from lv_drivers/display at master · lvgl/lv_drivers · GitHub
I have LCD module 3.2inch SPI Module ILI9341 SKU:MSP3218 - LCD wiki
Raspberry Pi Pico W
Use LCD
Tried to debug SPI with oscilloscope with SPI decode, it showed that data sending functions are working property, I checked that init sequence appearing on MOSI line same as in driver file, so SPI is working.
Tried different driver from pico-displayDrivs/ili9341 at main · tvlad1234/pico-displayDrivs · GitHub and it is semi working - text labels are shown on screen, but text is stretched, like italic, and some horizontal dark stripes - so there should be some problems in code.
Original code from getting started section of LVGL 8.3 documentation. Just inserted SPI functions from Raspbery Pi Pico SDK in github . com/lvgl/lv_drivers/blob/master/lv_drv_conf_template.h, and checked - they are working. Basically there are only external functions that called by ili9341 lv_driver:
void ILI9341_WriteByte(uint8_t data)
spi_set_format(ili9341_spi, 8, SPI_CPOL_1, SPI_CPHA_1, SPI_MSB_FIRST);
spi_write_blocking(ili9341_spi, &data, sizeof(data));
void ILI9341_WriteArray(uint8_t *buff, size_t buff_size)
spi_write_blocking(ili9341_spi, buff, buff_size);
Also lv_drv_conf.h
#define LV_DRV_DISP_CMD_DATA(val) gpio_put(ili9341_pinDC, val)/*pin_x_set(val)*/ /*Set the command/data pin to 'val'*/
#define LV_DRV_DISP_RST(val) gpio_put(ili9341_pinRST, val)/*pin_x_set(val)*/ /*Set the reset pin to 'val'*/
#define LV_DRV_DISP_LED(val) gpio_put(ili9341_pinLED, val)/*spi_cs_set(val)*/ /*Set the SPI's Chip select to 'val'*/
* SPI
// #define LV_DRV_DISP_SPI_CS(val) ILI9341_SetCS(val)/*spi_cs_set(val)*/ /*Set the SPI's Chip select to 'val'*/
#define LV_DRV_DISP_SPI_CS(val) gpio_put(ili9341_pinCS, val)/*spi_cs_set(val)*/ /*Set the SPI's Chip select to 'val'*/
#define LV_DRV_DISP_SPI_WR_BYTE(data) ILI9341_WriteByte(data)/*spi_wr(data)*/ /*Write a byte the SPI bus*/
#define LV_DRV_DISP_SPI_WR_ARRAY(adr, n) ILI9341_WriteArray(adr, n)/*spi_wr_mem(adr, n)*/ /*Write 'n' bytes to SPI bus from 'adr'*/
What next debug steps could be?
Can anybody confirm that ILI9341 lv_driver is working?
