After testing, I found out: The coordinates of tileview
widget are based on LV_HOR_RES_MAX
and LV_VER_RES_MAX
. right?
when i use follow code ,The logic of tileview
widget is error.
static void widget_tileview2(void)
const uint16_t hor_size = 150;//300 ok,but 200,150 issure
const uint16_t ver_size = 300;
static lv_point_t valid_pos[] = { {0,0}, {1, 0}, {2,0}, {3,0}, {0,1}, {0,2}, {0,3}, {0,4}};
static lv_style_t style;
lv_style_init(&style);
lv_style_set_pad_top(&style, LV_STATE_DEFAULT, 0);
lv_style_set_pad_left(&style, LV_STATE_DEFAULT, 0);
lv_style_set_pad_right(&style, LV_STATE_DEFAULT, 0);
lv_style_set_pad_bottom(&style, LV_STATE_DEFAULT, 0);
lv_obj_t* bg = lv_obj_create(lv_scr_act(), NULL);
lv_obj_set_size(bg, hor_size, ver_size);
lv_obj_align(bg, NULL, LV_ALIGN_CENTER, 0, 0);
lv_obj_add_style(bg, LV_OBJ_PART_MAIN, &style);
lv_obj_t* tileview;
tileview = lv_tileview_create(bg, NULL);
lv_tileview_set_valid_positions(tileview, valid_pos, 8);
lv_tileview_set_edge_flash(tileview, true);
for (int i = 0; i < 4; i++) {
lv_obj_t* par = lv_obj_create(tileview, NULL);
lv_obj_set_size(par, hor_size, ver_size);
lv_obj_set_pos(par, i * hor_size, 0);
lv_tileview_add_element(tileview, par);
lv_obj_t* label = lv_label_create(par, NULL);
lv_label_set_text_fmt(label, "this is (%d,%d)",i,0);
lv_obj_align(label, NULL, LV_ALIGN_CENTER, 0, 0);
for (int i = 1; i < 5; i++) {
lv_obj_set_pos(par, 0, i * ver_size);
lv_label_set_text_fmt(label, "this is (%d,%d)", 0, i);
but when
hor_size = LV_HOR_RES_MAX and ver_size = LV_VER_RES_MAX
, is ok.
Shouldn’t it depend on his father? is bug?
