I have an input field (text area) where the user can input a numeric data. When it is focused the built-in numeric keyboard appears. I am trying to use the keyboard’s checkmark (✓) to defocus a text area when the user is done with inputting the data. I save the input data from the UI in the defocus event hander.
If I defocus the text area by tapping somewhere on an empty area everything works fine, but when I want to defocus it programmatically with functions, I am able to do the defocusing part, but I am not able to refocus the text area again by tapping on it again for several seconds. It is not getting focused and the keyboard is not appearing when I touch it. If I tap somewhere empty beforehand, it works fine again even if it was defocused with the keyboard’s checkmark (✓) . Is there some other functions I need to call to be able to focus it again after defocusing it with functions?
STM32F767 nucleo board
9.2
I can make it work if I simulate a touch at an empty space with the keyboard’s checkmark (✓) but I want a cleaner solution.
I tried this method:
lv_obj_clear_state(obj, LV_STATE_FOCUSED);
and I also tried triggering the defocus event:
lv_obj_send_event(obj, LV_EVENT_DEFOCUSED, NULL);
Both of them are doing the defocusing part, but I cant refocus the text area by touching it again right after I defocused it for several seconds.
