Windows
v9.1.0
display the value of the pressed point for the faded line chart.
static void pupup_value_pressed_point(lv_event_t * e);
static void faded_line_chart_designed(lv_event_t * e);
void lv_example_chart_3_with_5(void)
/*Create a chart*/
lv_obj_t * chart;
chart = lv_chart_create(lv_screen_active());
lv_obj_set_size(chart, 200, 150);
lv_obj_center(chart);
/* popup value */
lv_obj_add_event_cb(chart, pupup_value_pressed_point, LV_EVENT_ALL, NULL);
/* gradient line chart */
lv_obj_add_flag(chart, LV_OBJ_FLAG_SEND_DRAW_TASK_EVENTS);
lv_obj_add_event_cb(chart, faded_line_chart_designed, LV_EVENT_DRAW_TASK_ADDED, NULL);
lv_obj_refresh_ext_draw_size(chart);
/*Zoom in a little in X*/
// lv_chart_set_scale_x(chart, 800);
/*Add two data series*/
lv_chart_series_t * ser1 = lv_chart_add_series(chart, lv_palette_main(LV_PALETTE_RED), LV_CHART_AXIS_PRIMARY_Y);
lv_chart_series_t * ser2 = lv_chart_add_series(chart, lv_palette_main(LV_PALETTE_GREEN), LV_CHART_AXIS_PRIMARY_Y);
uint32_t i;
for(i = 0; i < 10; i++) {
lv_chart_set_next_value(chart, ser1, lv_rand(60, 90));
lv_chart_set_next_value(chart, ser2, lv_rand(10, 40));
lv_obj_t * chart = (lv_obj_t *) lv_event_get_target(e);
if(code == LV_EVENT_VALUE_CHANGED) {
lv_obj_invalidate(chart);
if(code == LV_EVENT_REFR_EXT_DRAW_SIZE) {
int32_t * s = (int32_t *)lv_event_get_param(e);
*s = LV_MAX(*s, 20);
else if(code == LV_EVENT_DRAW_POST_END) {
int32_t id = lv_chart_get_pressed_point(chart);
if(id == LV_CHART_POINT_NONE) return;
LV_LOG_USER("Selected point %d", (int)id);
lv_chart_series_t * ser = lv_chart_get_series_next(chart, NULL);
while(ser) {
lv_point_t p;
lv_chart_get_point_pos_by_id(chart, ser, id, &p);
int32_t * y_array = lv_chart_get_y_array(chart, ser);
int32_t value = y_array[id];
char buf[16];
lv_snprintf(buf, sizeof(buf), LV_SYMBOL_DUMMY"$%d", value);
lv_draw_rect_dsc_t draw_rect_dsc;
lv_draw_rect_dsc_init(&draw_rect_dsc);
draw_rect_dsc.bg_color = lv_color_black();
draw_rect_dsc.bg_opa = LV_OPA_50;
draw_rect_dsc.radius = 3;
draw_rect_dsc.bg_image_src = buf;
draw_rect_dsc.bg_image_recolor = lv_color_white();
draw_rect_dsc.bg_image_symbol_font = &prasanmit_20;
lv_area_t a;
a.x1 = chart->coords.x1 + p.x - 20;
a.x2 = chart->coords.x1 + p.x + 20;
a.y1 = chart->coords.y1 + p.y - 30;
a.y2 = chart->coords.y1 + p.y - 10;
lv_layer_t * layer = lv_event_get_layer(e);
lv_draw_rect(layer, &draw_rect_dsc, &a);
ser = lv_chart_get_series_next(chart, ser);
else if(code == LV_EVENT_RELEASED) {
lv_draw_task_t * draw_task = lv_event_get_draw_task(e);
lv_draw_dsc_base_t * base_dsc = (lv_draw_dsc_base_t *)draw_task->draw_dsc;
if(base_dsc->part == LV_PART_ITEMS && draw_task->type == LV_DRAW_TASK_TYPE_LINE) {
lv_obj_t * obj = (lv_obj_t *)lv_event_get_target(e);
const lv_chart_series_t * ser = lv_chart_get_series_next(obj, NULL);
for(int i = 0; i < base_dsc->id1; i++) {
ser = lv_chart_get_series_next(obj, ser);
if(ser == NULL) return;
/*Draw a triangle below the line witch some opacity gradient*/
lv_draw_line_dsc_t * draw_line_dsc = (lv_draw_line_dsc_t *)draw_task->draw_dsc;
lv_draw_triangle_dsc_t tri_dsc;
lv_draw_triangle_dsc_init(&tri_dsc);
tri_dsc.p[0].x = draw_line_dsc->p1.x;
tri_dsc.p[0].y = draw_line_dsc->p1.y;
tri_dsc.p[1].x = draw_line_dsc->p2.x;
tri_dsc.p[1].y = draw_line_dsc->p2.y;
tri_dsc.p[2].x = draw_line_dsc->p1.y < draw_line_dsc->p2.y ? draw_line_dsc->p1.x : draw_line_dsc->p2.x;
tri_dsc.p[2].y = LV_MAX(draw_line_dsc->p1.y, draw_line_dsc->p2.y);
tri_dsc.bg_grad.dir = LV_GRAD_DIR_VER;
int32_t full_h = lv_obj_get_height(obj);
int32_t fract_uppter = (int32_t)(LV_MIN(draw_line_dsc->p1.y, draw_line_dsc->p2.y) - obj->coords.y1) * 255 / full_h;
int32_t fract_lower = (int32_t)(LV_MAX(draw_line_dsc->p1.y, draw_line_dsc->p2.y) - obj->coords.y1) * 255 / full_h;
tri_dsc.bg_grad.stops[0].color = ser->color;
tri_dsc.bg_grad.stops[0].opa = 255 - fract_uppter;
tri_dsc.bg_grad.stops[0].frac = 0;
tri_dsc.bg_grad.stops[1].color = ser->color;
tri_dsc.bg_grad.stops[1].opa = 255 - fract_lower;
tri_dsc.bg_grad.stops[1].frac = 255;
lv_draw_triangle(base_dsc->layer, &tri_dsc);
/*Draw rectangle below the triangle*/
lv_draw_rect_dsc_t rect_dsc;
lv_draw_rect_dsc_init(&rect_dsc);
rect_dsc.bg_grad.dir = LV_GRAD_DIR_VER;
rect_dsc.bg_grad.stops[0].color = ser->color;
rect_dsc.bg_grad.stops[0].frac = 0;
rect_dsc.bg_grad.stops[0].opa = 255 - fract_lower;
rect_dsc.bg_grad.stops[1].color = ser->color;
rect_dsc.bg_grad.stops[1].frac = 255;
rect_dsc.bg_grad.stops[1].opa = 0;
lv_area_t rect_area;
rect_area.x1 = (int32_t)draw_line_dsc->p1.x;
rect_area.x2 = (int32_t)draw_line_dsc->p2.x - 1;
rect_area.y1 = (int32_t)LV_MAX(draw_line_dsc->p1.y, draw_line_dsc->p2.y) - 1;
rect_area.y2 = (int32_t)obj->coords.y2;
lv_draw_rect(base_dsc->layer, &rect_dsc, &rect_area);
