I create a page with some buttons on this page.
And create a new transparent layer
for receiving some signals to resize the page
by set this new layer to LV_PROTECT_PARENT | LV_PROTECT_PRESS_LOST …
and set the layer’s parent again back to the page’s bg.
( As the page’s property, the buttons’ parent is automatically
moved to the page’ scrollable-container.
But the layer’s parent is set back to the page’ bg container )
As this scenario
when draging signal occur,
I can receive some the layer’s signal to resize the page already.
But if the layer is pressed, I want to send this pressed-signal
from the layer to the buttons on the page
that under the layer too.
how to send this signal to the button under the layer?
Thank you.
- ESP32
Send pressed signal on the layer that cover the page
to the button under the layer too.
lv_obj_t* page = lv_page_create(lv_scr_act(), NULL);
lv_obj_set_size( page, 240,240);
lv_page_set_scrl_layout( page, LV_LAYOUT_GRID);
lv_obj_t* btn1 = lv_btn_create( page, NULL);
lv_obj_t* btn2 = lv_btn_create( page, NULL);
lv_obj_t* btn3 = lv_btn_create( page, NULL);
lv_obj_t* layer = lv_cont_create( page, NULL);
lv_obj_set_protect(layer, LV_PROTECT_PARENT | LV_PROTECT_PRESS_LOST );
lv_obj_set_parent(layer, page);
lv_obj_move_foreground(layer);
lv_obj_set_style(layer, &lv_style_transp);
lv_cont_set_fit( layer, LV_FIT_FLOOD);
lv_obj_set_drag( layer, true);
lv_obj_set_drag_throw( layer, true);
lv_obj_align( layer, page, LV_ALIGN_CENTER,0,0);
static lv_res_t layer_signal(lv_obj_t * op_resizer, lv_signal_t sign, void * param)
if( sign == LV_SIGNAL_PRESSED || sign == LV_SIGNAL_PRESSING ) {
... // draging to change size of the page
... // how to send these signal to the buttons too ?
