I have created a button & Input dev using LV_INDEV_TYPE_BUTTON. I don’t what’s wrong in my code?. Whenever I press a pushbutton(which is connected to our dev board(STM32F207)) then I got debug print push-button pressed. But there is no change in UI button?. I have looked soo many examples& issues but all are related old versions that example API’s are not available in the latest LVGL version v7.3
STM32F207zg nucleo board
v7.3
/* Key Input Test /
static lv_group_t* ModeGroup;
void my_button_init( void )
static lv_indev_t *indev_button;
lv_indev_drv_t indev_drv;
/Register a button input device/
indev_drv.type = LV_INDEV_TYPE_BUTTON;
indev_drv.read_cb = my_input_read;
indev_button = lv_indev_drv_register(&indev_drv);
/Assign buttons to points on the screen/
static const lv_point_t btn_points[ ] = {
{1, 1} /Button 0 -> x:1; y:1/
lv_indev_set_button_points(indev_button, btn_points);
ModeGroup = lv_group_create();
uint8_t my_btn_read( void )
if(HAL_GPIO_ReadPin(MODE_GPIO_Port, MODE_Pin) == 0)
return 1;
return 0;
bool my_input_read(lv_indev_data_t data)
static int8_t last_btn = 0; / Store the last pressed button /
int8_t btn_pr = my_btn_read(); / Get the ID (0,1,2...) of the pressed button */
if(btn_pr > 0) { /* Is there a button press? */
last_btn = btn_pr; /* Save the ID of the pressed button */
data->state = LV_INDEV_STATE_PR; /* Set the pressed state */
HAL_UART_Transmit(&huart6,"LV_INDEV_STATE_PR\r\n",strlen("LV_INDEV_STATE_PR\r\n"), 1000);
else {
data->state = LV_INDEV_STATE_REL; /* Set the released state */
lv_group_focus_freeze(ModeGroup,0);
data->btn_id = last_btn; /* Set the last button */
return false; /* No buffering so no more data read */
/* Key Test /
lv_style_t style_btn;
void btn_event_cb(lv_obj_t * btn, lv_event_t event)
sprintf(DBGBuff,"BTN_CB:%d\r\n",event);
HAL_UART_Transmit(&huart6,DBGBuff,strlen(DBGBuff), 1000);
if(event == LV_EVENT_PRESSED)
HAL_UART_Transmit(&huart6,"Clicked\r\n",strlen("Clicked\r\n"), 1000);
static uint8_t cnt = 0;
cnt++;
/*Get the first child of the button which is the label and change its text*/
lv_obj_t * label = lv_obj_get_child(btn, NULL);
lv_label_set_recolor(label, true);
lv_label_set_text_fmt(label, "#FFFFFF MODE: %d#", cnt);
Create a button with a label and react on Click event.
void lv_usr_Mode_B1(void)
//static lv_style_t style_btn;
/Create a simple button style/
lv_style_init(&style_btn);
lv_style_set_radius(&style_btn, LV_STATE_DEFAULT, 1);
lv_style_set_bg_opa(&style_btn, LV_STATE_DEFAULT, LV_OPA_COVER);
lv_style_set_bg_color(&style_btn, LV_STATE_DEFAULT, LV_COLOR_NAVY);
lv_style_set_bg_grad_color(&style_btn, LV_STATE_DEFAULT, LV_COLOR_AQUA);
lv_style_set_bg_grad_dir(&style_btn, LV_STATE_DEFAULT, LV_GRAD_DIR_VER);
/Swap the colors in pressed state/
lv_style_set_bg_color(&style_btn, LV_STATE_PRESSED, LV_COLOR_ORANGE);
lv_style_set_bg_grad_color(&style_btn, LV_STATE_PRESSED, LV_COLOR_SILVER);
/Add a border/
lv_style_set_border_color(&style_btn, LV_STATE_DEFAULT, LV_COLOR_BLACK);
lv_style_set_border_opa(&style_btn, LV_STATE_DEFAULT, LV_OPA_70);
lv_style_set_border_width(&style_btn, LV_STATE_DEFAULT, 1);
lv_obj_t * btn = lv_btn_create(lv_scr_act(), NULL); /Add a button the current screen/
lv_obj_set_pos(btn, 1, 1); /Set its position/
lv_obj_set_size(btn, 80, 40); /Set its size/
lv_obj_set_event_cb(btn, btn_event_cb); /Assign a callback to the button/
lv_obj_t * label = lv_label_create(btn, NULL); /Add a label to the button/
lv_label_set_recolor(label, true); /Enable re-coloring by commands in the text/
lv_label_set_text(label, "#FFFFFF MODE#"); /Set the labels text/
lv_obj_add_style(btn, LV_BTN_PART_MAIN, &style_btn);
//lv_obj_set_free_num(btn, 1); /Set a unique number for the button/
lv_group_add_obj(ModeGroup, btn);
