STM32F429ZIT6. Display Resolution 800*480, pixel - 16 bit
8.3.3
Improve performance by utilizing LTDC peripheral’s both layers.
Only Layer 1
@kisvegabor can you help on this.
I think using 2 layers is not the best way (at least not a generic way) to improve the performance.
I suggest to take look at this Introduction — LVGL documentation
Hello, I have tried the *suggestions mentioned in the link. But the refreshing is still slow. Video link
*Also tried double buffering, but it doesn’t make any difference. So, used only single buffer.
Display Resolution 800*480 (Landscape).
I have also attached lvgl config files. tft.c (7.1 KB), lv_conf.h (25.1 KB)
Regards,
Keshav Aggarwal
I think it’s slow because of disp_drv.sw_rotate = 1;
You can increase LV_DISP_ROT_MAX_BUF
to 40*1024
. Does it make any difference?
Be sure compiler optimization is set to -O2 or -O3.
Note that using DMA this way in the flush_cb
won’t work later if only parts of the screen is updated. For the sake of simplicity I suggest using something like this for now.
Hello. Thanks for replying,
I have tried LV_DISP_ROT_MAX_BUF
to 40*1024
. Still no difference.
opt level is already set to -O3.
I also tried replacing DMA with below. The colors got distorted and refresh speed was a bit slower as compared with DMA (Not much).
uint32_t w = lv_area_get_width(area);
for(y = area->y1; y <= area->y2 && y < vres; y++) {
memcpy(&monitor.tft_fb[y * hres + area->x1], color_p, w * sizeof(lv_color_t));
color_p += w;
