Beaglebone Black with RTEMS (FreeBSD FrameBuffer)
Waveshare 5inch HDMI LCD (H)
Be able to use touchscreen or mouse as an input device
I tried to work with evdev drivers but I think linux/input.h and some of the other headers undefined in RTEMS.
lv_drive_conf.h
#ifndef USE_EVDEV
# define USE_EVDEV 1
#if USE_EVDEV
# define EVDEV_NAME "/dev/input/event0" /*You can use the "evtest" Linux tool to get the list of devices and test them*/
# define EVDEV_SWAP_AXES 0 /*Swap the x and y axes of the touchscreen*/
# define EVDEV_SCALE 0 /* Scale input, e.g. if touchscreen resolution does not match display resolution */
# if EVDEV_SCALE
# define EVDEV_SCALE_HOR_RES (800) /* Horizontal resolution of touchscreen */
# define EVDEV_SCALE_VER_RES (480) /* Vertical resolution of touchscreen */
# endif /*EVDEV_SCALE*/
# define EVDEV_CALIBRATE 0 /*Scale and offset the touchscreen coordinates by using maximum and minimum values for each axis*/
# if EVDEV_CALIBRATE
# define EVDEV_HOR_MIN 3800 /*If EVDEV_XXX_MIN > EVDEV_XXX_MAX the XXX axis is automatically inverted*/
# define EVDEV_HOR_MAX 200
# define EVDEV_VER_MIN 200
# define EVDEV_VER_MAX 3800
#endif /*USE_EVDEV*/
My evdev code
#include <fbdev.h>
#include "lvgl/lvgl.h"
#include "evdev.h"
evdev_init();
lv_indev_drv_t indev_drv;
indev_drv.read_cb = evdev_read;
I am trying to make an HMI system with RTEMS on BBB. I am using one of the samples in lv_tutorials but I can’t use any widget’s event. Is there any way to use touchscreen or mouse with BSD fb?
