ESP32S3
LVGL9.1
use TE signal as display refrash trigger
I try adding lv_display_delete_refr_timer(disp) in lv_port_disp_init function, than call _lv_display_refr_timer(NULL) in TE call back function.
I also try adding _lv_display_refr_timer(NULL) in the main loop but it crash in my ESP32S3 dev board。
/*Delete the original display refresh timer*/
lv_disp_t * disp = lv_disp_get_default();
while(1) {
/* Periodically call the lv_task handler.
* It could be done in a timer interrupt or an OS task too.*/
lv_timer_handler();
usleep(5 * 1000);
/*Call this anywhere you want to refresh the dirty areas*/
_lv_display_refr_timer(NULL);
