How to use lvgl with SDL?
For now UBUNTU on intel
To use SDL driver
Wyaland and windows driver
So the sdl driver is as this for my hal_init:
#if USE_SDL
#include <lvgl.h>
#include <sdl/sdl.h>
bool hal_init(void)
sdl_init();
/*Create a display buffer*/
static lv_disp_draw_buf_t disp_buf1;
static lv_color_t buf1_1[SDL_HOR_RES * 100];
lv_disp_draw_buf_init(&disp_buf1, buf1_1, NULL, SDL_HOR_RES * 100);
/*Create a display*/
disp_drv.draw_buf = &disp_buf1;
disp_drv.flush_cb = sdl_display_flush;
disp_drv.hor_res = SDL_HOR_RES;
disp_drv.ver_res = SDL_VER_RES;
lv_disp_t * disp = lv_disp_drv_register(&disp_drv);
lv_theme_t * th = lv_theme_default_init(disp, lv_palette_main(LV_PALETTE_BLUE), lv_palette_main(LV_PALETTE_RED), LV_THEME_DEFAULT_DARK, LV_FONT_DEFAULT);
lv_disp_set_theme(disp, th);
lv_group_t * g = lv_group_create();
lv_group_set_default(g);
LV_LOG_USER("SDL driver set.");
return true;
The lvgl is crashing here:
It seems disp_refr is not well initialized. What am I doing wrong?
I would also like to try drm driver, is there any example on how to use this?
Thank you!
Ok, never mind.
I changed the code to the following and now it’s working:
#if USE_SDL
#include <lvgl.h>
bool hal_init(void)
sdl_init();
void * buf1 = lv_mem_alloc(SDL_HOR_RES * SDL_VER_RES * sizeof(lv_color_t));
lv_disp_draw_buf_init(&disp_buf1, buf1, NULL, SDL_HOR_RES * SDL_VER_RES);
/* Register input */
static lv_indev_drv_t lv_indev_drv_pointer;
lv_indev_drv_pointer.type = LV_INDEV_TYPE_POINTER;
lv_indev_drv_pointer.read_cb = sdl_mouse_read;
lv_indev_t *mouse_indev = lv_indev_drv_register(&lv_indev_drv_pointer);
LV_FONT_DEFAULT);
return true;
I haven’t tried yet on my hardware, but does this SDL driver support touch events?
Thanks
I think SDL support touch events. You should check if your hardware environment has correct device tree and SDL lib firstly.
Try ls /dev/input/
Thank you. The sdl_mouse_read callback did the trick. It was enough to have touch events.
