I am using Gui Guider 1.4.1-GA with LVGL 8.2 (and Micropython). I am not using any hardware yet, just trying out the widgets and trying to understand the event model.
I have two images and I want them both hidden initially, on a button press a calculation is performed and depending on the result one of the two images is shown. Then there is a Clear button and they can both be hidden again.
I have the buttons working as I want, the only thing I can’t figure out is how to make them initially hidden. My guess is I would want to use either LV_EVENT_SCREEN_LOAD_START or LV_EVENT_SCREEN_LOADED. I don’t quite know what these events should be attached to, the images I want to hide or some screen object?
I’ve tried adding this to my custom.py, based on copying code that is generated in guiguider.py, but it is not quite right. Gui Guider doesn’t give much in the way of output when the Micropython fails to run, so I don’t have any debug output.
def hide_cb(e, img_to_hide):
src = e.get_target()
code = e.get_code()
img_to_hide.add_flag(lv.obj.FLAG.HIDDEN)
screen_img_happy.add_event_cb(lambda e: hide_cb(e, screen_img_happy), lv.event.SCREEN_LOADED, None)
screen_img_angry.add_event_cb(lambda e: hide_cb(e, screen_img_angry), lv.event.SCREEN_LOADED, None)
thank you.
