I can not find any example for v8.3. But in manual v8.3 it said this version support mask function.
Could you give me some example?
Hey, there is this page in the docs for v8.3 about masking.
Thanks a lot, I made it. But after I add the mask, it will like window-shades.
I want to get:
But I got:
This is my code:
* DEFINES
const lv_coord_t mask_width = 792;
const lv_coord_t mask_height = 202;
* TYPEDEFS
* STATIC PROTOTYPES
static void hal_init(void);
static int tick_thread(void *data);
* STATIC VARIABLES
lv_ui guider_ui;
* MACROS
/* Create the mask of a text by drawing it to a canvas*/
lv_color_t mask_map[LV_CANVAS_BUF_SIZE_TRUE_COLOR_ALPHA(792,202)];
static void mask_event_cb(lv_event_t * e);
* GLOBAL FUNCTIONS
int APIENTRY WinMain(HINSTANCE hInstance, HINSTANCE hPrevInstance, LPSTR szCmdLine, int nCmdShow)
int i;
/*Initialize LittlevGL*/
/*Initialize the HAL for LittlevGL*/
lv_win32_init(hInstance, SW_SHOWNORMAL, 800, 480, NULL);
/*Output prompt information to the console, you can also use printf() to print directly*/
LV_LOG_USER("LVGL initialization completed!");
/*Run the demo*/
//lv_demo_widgets();
setup_ui(&guider_ui);
lv_obj_add_event_cb(guider_ui.screen_img_1, mask_event_cb, LV_EVENT_ALL, guider_ui.screen_img_1);
while(!lv_win32_quit_signal) {
/* Periodically call the lv_task handler.
* It could be done in a timer interrupt or an OS task too.*/
lv_task_handler();
usleep(10000); /*Just to let the system breath*/
return 0;
static void mask_event_cb(lv_event_t * e) {
static lv_draw_mask_map_param_t m;
static int16_t mask_id;
if (code == LV_EVENT_COVER_CHECK) {
lv_event_set_cover_res(e, LV_COVER_RES_MASKED);
else if (code == LV_EVENT_DRAW_MAIN_BEGIN) {
/*Create a "8 bit alpha" canvas and clear it*/
lv_obj_t* canvas = lv_canvas_create(lv_scr_act());
lv_canvas_set_buffer(canvas, mask_map, mask_width, mask_height, LV_IMG_CF_TRUE_COLOR_ALPHA);
lv_canvas_fill_bg(canvas, lv_color_black(), LV_OPA_TRANSP);
/*Draw a label to the canvas. The result "image" will be used as mask*/
lv_draw_rect_dsc_t rect_dsc;
lv_draw_rect_dsc_init(&rect_dsc);
rect_dsc.radius = 0;
rect_dsc.bg_opa = LV_OPA_COVER;
rect_dsc.bg_color = lv_color_white();
rect_dsc.bg_grad.dir = LV_GRAD_DIR_NONE;
rect_dsc.border_width = 0;
lv_canvas_draw_rect(canvas, 0, 0, 150, 100, &rect_dsc);
/*The mask is reads the canvas is not required anymore*/
lv_obj_del(canvas);
/* Create an object from where the text will be masked out.
* Now it's a rectangle with a gradient but it could be an image too*/
lv_draw_mask_map_init(&m, &obj->coords, mask_map);
mask_id = lv_draw_mask_add(&m, NULL);
else if (code == LV_EVENT_DRAW_MAIN_END) {
lv_draw_mask_free_param(&m);
lv_draw_mask_remove_id(mask_id);
