Hi, I’m trying to display a png to the screen by opening it from the file path “/mnt/flash/nexion.png”. However, every time I try to open this file up using the line img_set_src(img, “/mnt/flash/nexion.png”), I’m told that the file cannot be opened because it contains an unknown driver letter. The error is: lv_fs_open: Can’t open file ("/mnt/flash/nexion.png): unknown driver letter. I’m not sure why it is even using lv_fs_open to begin with. On this website: https://github.com/lvgl/lv_lib_png, it says that by deafult lodepng uses C file IO API (e.g. fopen) and images can be opened like this:
lv_img_set_src(img, “./lv_lib_png/png_decoder_test.png”). fopen works for me when using the call fopen("/mnt/flash/testfile.txt") so why would it not work when I’m setting the img_src in the same way?
Xilinx Zyng Development Board
Version 8.1
I want to render a png to the screen without having to use the online decoder. I want to decode the png image to a C file and display it right away on the screen. I don’t mind doing so in a longer way - like using lodepng directly instead of using the lv_img_set_src function. However, I do not know what function to call to do so
I have tried putting the png file in a folder on my windows C drive and using the absolute path in the call set_img_src(img, “C:/users/matth/…”). I had to register a driver to do so in main.c but had no luck with it and the documentation was not easy to follow. I added #define LV_USE_PNG 1 in lv_conf.h and lv_conf_internal.h. Then I added the snippet of code below to a testing page but it gives me the error of an unknown driver letter described above and an inability to properly open the file.
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <fcntl.h>
#include "../lvgl/lvgl.h"
#include "controlTab.h"
#include "global.h"
#include "../lvgl/src/extra/libs/png/lv_png.h"
/* STATIC - PRIVATE VARIABLES */
static lv_obj_t * backButton;
static lv_obj_t * container;
static lv_obj_t * chart;
static lv_chart_series_t * ser;
static lv_chart_cursor_t * cursor;
/* FUNCTION DECLARATIONS */
static void BackButtonPressed(lv_event_t * event);
void TestingPageInit(void)
container = lv_obj_create(controlTab);
lv_obj_set_size(container, lv_obj_get_width(controlTab), lv_obj_get_height(controlTab)/2);
lv_obj_center(container);
lv_obj_t * label = lv_label_create(container);
backButton = lv_btn_create(controlTab);
lv_obj_align(backButton, LV_ALIGN_CENTER, -290, 110);
lv_obj_set_size(backButton, 120, 60);
lv_obj_t *label1 = lv_label_create(backButton);
lv_label_set_text(label1, LV_SYMBOL_BACKSPACE " BACK");
lv_obj_add_event_cb(backButton, BackButtonPressed, LV_EVENT_CLICKED, NULL);
lv_png_init();
//LV_IMG_DECLARE(png_decoder_test);
lv_obj_t * img = lv_img_create(lv_scr_act());
//lv_img_set_src(img, "./mnt/flash/nexion.png");
lv_img_set_src(img, "P:/users/matth/downloads/nexion.png");
