I have a function that is called to plot scatter x-y data on chart. The API function lv_chart_set_next_value2(chart_op, ser_st, x, y) is used to plot data no the chart, is work well :
void plot_st_data(uint16_t x, uint16_t y) {
uint16_t id_data = x / dt;
//lv_chart_set_value_by_id2(chart_op, ser_st, id_data, x, y);
lv_chart_set_next_value2(chart_op, ser_st, x, y);
printf("plot data : id=%d , x=%d, y=%d \n", id_data, x, y);
//lv_chart_refresh(chart_op);
//lv_refr_now(NULL);
In order to modify the specific data, the API
is replaced with
But lv_chart_set_value_by_id2() does not work correctly, there is not thing on the chart.
VisualStudio Simulator
v8.0
Use the API lv_chart_set_value_by_id2(chart_op, ser_st, id_data, x, y) to plot chart, hence the specific data can be modified via id_data.
I replace lv_chart_set_next_value2(chart_op, ser_st, x, y);
with
But it does not work correctly.
BTW, I have checked the API lv_chart_set_value_by_id2(chart_op, ser_st, id_data, x, y); in lv_example_chart_7, It’s work correctly!
//lv_chart_set_next_value2(chart_op, ser_st, x, y);
lv_refr_now(NULL);
Thanks for your suggestion, Best Wishes.
