Hi everyone,
I’m currently trying to use LittleFS for Esp32 but I’m facing an issue with how the fs_open
is working.
#include <Arduino.h>
#include "lv_port_fs_littlefs.h"
#include <LittleFS.h>
static void fs_init(void);
static void * fs_open(lv_fs_drv_t * drv, const char * path, lv_fs_mode_t mode);
static lv_fs_res_t fs_close(lv_fs_drv_t * drv, void * file_p);
static lv_fs_res_t fs_read(lv_fs_drv_t * drv, void * file_p, void * buf, uint32_t btr, uint32_t * br);
static lv_fs_res_t fs_write(lv_fs_drv_t * drv, void * file_p, const void * buf, uint32_t btw, uint32_t * bw);
static lv_fs_res_t fs_seek(lv_fs_drv_t * drv, void * file_p, uint32_t pos, lv_fs_whence_t whence);
static lv_fs_res_t fs_size(lv_fs_drv_t * drv, void * file_p, uint32_t * size_p);
static lv_fs_res_t fs_tell(lv_fs_drv_t * drv, void * file_p, uint32_t * pos_p);
static void * fs_dir_open(lv_fs_drv_t * drv, const char * path);
static lv_fs_res_t fs_dir_read(lv_fs_drv_t * drv, void * rddir_p, char * fn);
static lv_fs_res_t fs_dir_close(lv_fs_drv_t * drv, void * rddir_p);
void lv_port_littlefs_init(void)
fs_init();
/*Add a simple drive to open images*/
static lv_fs_drv_t fs_drv;
lv_fs_drv_init(&fs_drv);
fs_drv.letter = 'L';
fs_drv.open_cb = fs_open;
fs_drv.close_cb = fs_close;
fs_drv.read_cb = fs_read;
fs_drv.write_cb = fs_write;
fs_drv.seek_cb = fs_seek;
fs_drv.tell_cb = NULL;
fs_drv.dir_close_cb = NULL;
fs_drv.dir_open_cb = NULL;
fs_drv.dir_read_cb = NULL;
lv_fs_drv_register(&fs_drv);
* STATIC FUNCTIONS
/*Initialize your Storage device and File system.*/
LittleFS.begin();
* Open a file
* @param drv pointer to a driver where this function belongs
* @param path path to the file beginning with the driver letter (e.g. S:/folder/file.txt)
* @param mode read: FS_MODE_RD, write: FS_MODE_WR, both: FS_MODE_RD | FS_MODE_WR
* @return a file descriptor or NULL on error
LV_UNUSED(drv);
const char * flags = "";
if (mode == LV_FS_MODE_WR) flags = FILE_WRITE;
else if (mode == LV_FS_MODE_RD) flags = FILE_READ;
else if (mode == (LV_FS_MODE_WR | LV_FS_MODE_RD)) flags = FILE_WRITE;
char complete_path[strlen(path) + 1];
complete_path[0] = '/';
complete_path[1] = '\0';
strcat(complete_path, path);
Serial.printf("Try to open file: %s\n", complete_path);
File f = LittleFS.open(complete_path, flags);
if (!f) {
Serial.printf("Error with file: %s\n", complete_path);
} else {
Serial.println(f.name());
time_t t = f.getLastWrite();
struct tm * tmstruct = localtime(&t);
Serial.printf(" LAST WRITE: %d-%02d-%02d %02d:%02d:%02d\n",(tmstruct->tm_year)+1900,( tmstruct->tm_mon)+1, tmstruct->tm_mday,tmstruct->tm_hour , tmstruct->tm_min, tmstruct->tm_sec);
return (void*)f;
* Close an opened file
* @param file_p pointer to a file_t variable. (opened with fs_open)
* @return LV_FS_RES_OK: no error or any error from @lv_fs_res_t enum
LV_UNUSED(drv);
File* file = (File*)file_p;
file->close();
return LV_FS_RES_OK;
* Read data from an opened file
* @param buf pointer to a memory block where to store the read data
* @param btr number of Bytes To Read
* @param br the real number of read bytes (Byte Read)
LV_UNUSED(drv);
*br = file->read((uint8_t*)buf, btr);
return (int32_t)(*br) < 0 ? LV_FS_RES_UNKNOWN : LV_FS_RES_OK;
* Write into a file
* @param buf pointer to a buffer with the bytes to write
* @param btw Bytes To Write
* @param bw the number of real written bytes (Bytes Written). NULL if unused.
LV_UNUSED(drv);
*bw = file->write((uint8_t*)buf, btw);
return (int32_t)(*bw) < 0 ? LV_FS_RES_UNKNOWN : LV_FS_RES_OK;
* Set the read write pointer. Also expand the file size if necessary.
* @param file_p pointer to a file_t variable. (opened with fs_open )
* @param pos the new position of read write pointer
* @param whence tells from where to interpret the `pos`. See @lv_fs_whence_t
LV_UNUSED(drv);
SeekMode mode;
if (whence == LV_FS_SEEK_SET) mode = SeekSet;
else if (whence == LV_FS_SEEK_CUR) mode = SeekCur;
else if (whence == LV_FS_SEEK_END) mode = SeekEnd;
file->seek(pos, mode);
It raises
lib/lv_conf/lv_port_fs_littlefs.cpp: In function 'void* fs_open(lv_fs_drv_t*, const char*, lv_fs_mode_t)':
lib/lv_conf/lv_port_fs_littlefs.cpp:85:17: error: invalid cast from type 'fs::File' to type 'void*'
return (void*)f;
*** [.pio/build/m5stack-core2/libe34/lv_conf/lv_port_fs_littlefs.cpp.o] Error 1
I don’t know how to make it work, files are correctly loaded:
Try to open file: /background/16.png
LAST WRITE: 2022-02-18 16:09:57
Try to open file: /home/title.png
LAST WRITE: 2022-01-28 21:09:00
As I already said in previous posts, I’m new in the C/C++ world
If you think it’s a good idea, I would be glad to create a pull request for LVGL to integrate LittleFS or SPIFFS as File System.
