I’m using v6.0.
When I generate larger size fonts (ex: 128) myself, moving the mouse can cause confusion in character display.
It should be fixed with https://github.com/littlevgl/lvgl/pull/1111
It it working with the latest dev-6.0 branch?
I’m using pc_simulator_sdl_eclipse branch dev-6.0, so the lvgl is not the latest version. I try to fix this problem by hand, and now it works fine. Please update the pc_simulator ! Thank you!
We do try to as often as possible, but it’s usually best to manually update it on your end as well.
