How to update a label object to show sensor value
ESP32
V8.1
Lebel gets update to show sensor values
Almost all methods by using Platform IO in VS code.
#include <lvgl.h>
#include "lv_conf.h"
void Show_Info();
void lv_buttons();
void setup(){
      lv_buttons();
void loop()
      show_info();
void Show_Info(){
      String P_Str = String(analogRead(A0));
      lv_obj_t *label_Pre = lv_label_create(lv_scr_act());
      lv_label_set_text(label_Pre, P_Str.c_str());  // set label text
      lv_obj_set_style_text_font(label_Pre, &lv_font_montserrat_48, 0);
      lv_obj_align(label_Pre, LV_ALIGN_TOP_LEFT, 20, 10);
void lv_buttons(){
After uploading, it runs well kept updating for 10 seconds and stuck. I believe the loop is keep creating object label_Pre until memory runs out.
Therefore, I move the lv_obj_t *label_Pre = lv_label_create(lv_scr_act()); outside of the function and placed it in setup() to run only once when powering on.
However, the lv_label_set_text(label_Pre, P_Str.c_str()); complained “identifier “label_Pre” is undefinedC/C++(20)”.
I tried many times but could not make it work. Pls help!
Also, I tried lv_task but does not supported in V8.
I tried LV_EVENT_REFRESH, no hope.
static void Sensor_valve_handler(lv_obj_t * obj, lv_event_t event){
if (event == LV_EVENT_REFRESH )
Same issue, the lv_label_set_text(label_Pre, P_Str.c_str()); complained “identifier “label_Pre” is undefinedC/C++(20)”.
Set lv_obj_t * label_Pre as a global object.
Then in your setup code call
And in your loop function call lv_label_set_text(…)
This will fix your initial issue of the memory leak causing your device to get stuck, and allow you to update it from your loop.
Very nice! It worked for me.
Thanks a lot, David!
My pleasure!
did you ever resolve issue? been playing with your code, and the lv_example_styleX seam to be the cause. guessing its duplication of objects.
I have been trying to figure out a way to cause Serial value updates to be event trigger
