I would like to Switch between Dark Mode and Light Mode using the lv_theme_default in V8.1.0
In the LVGL Master Branch Documentation:
https://docs.lvgl.io/master/overview/style.html
Under the Paragraph: Themes
The following is stated:
lv_theme_t * th = lv_theme_default_init(display, /*Use the DPI, size, etc from this display*/
LV_COLOR_PALETTE_BLUE, LV_COLOR_PALETTE_CYAN, /*Primary and secondary palette*/
false, /*Light or dark mode*/
&lv_font_montserrat_10, &lv_font_montserrat_14, &lv_font_montserrat_18); /*Small, normal, large fonts*/
lv_disp_set_theme(display, th); /*Assign the theme to the display*/
In this code excerpt from the documentation, as you can see they expect three font parameters i.e.
Small, Normal and Large Fonts.
However, in lv_theme_default.c the function is defined as:
lv_theme_t * lv_theme_default_init(lv_disp_t * disp, lv_color_t color_primary, lv_color_t color_secondary, bool dark, const lv_font_t * font)
and thus only takes one font parameter, and thus it fails to compile.
But in the code in lv_theme_default.c it does initialize all three fonts:
theme.disp = disp;
theme.color_primary = color_primary;
theme.color_secondary = color_secondary;
theme.font_small = font;
theme.font_normal = font;
theme.font_large = font;
theme.apply_cb = theme_apply;
theme.flags = dark ? MODE_DARK : 0;
I can probably assume that that would be the Normal font, but would like clarification please?
Can the documentation be updated to reflect the proper use case?.
I also note that the function is not included later on in the API functions section.
VSCode 1.58.0-insider, ESP32-WROOM-32E Devkit 4.0
Espressif plugin 1.1.0
ESP-IDF release/4.2
Win 10
KConfig used.
LVGL 8.1.0 (dev) i.e master.
Trying to switch between Dark and Light themes.
* @brief Sets the current theme Dark or Light
* Called from packhouse_config too.
void packhouse_set_theme(packhouse_config_t *ph)
lv_theme_t * th = lv_disp_get_theme(NULL);
//lv_disp_t * disp = obj ? lv_obj_get_disp(obj) : lv_disp_get_default();
lv_disp_t * disp = lv_disp_get_default();
bool flag = ph->ph_dark_mode ? 1 : 0;
//theme.flags = dark ? MODE_DARK : 0;
lv_theme_default_init(disp, th->color_primary, th->color_secondary,
flag,
th->font_small, th->font_normal, th->font_large);
Comment
This is probably not the best way of achieving my goal. I have purposely left in some of my comments in the code excerpt so others can see how I came to my conclusions when converting from V7 to V8.1.0
I’ll be thankful for any help.
