I assume you checked that the object reference you are using is not null? Or, perhaps whatever interrupt/clock mechanism you are using to call lv_tick_inc stops functioning?
Is there an API I can call to get the object reference? or do I just check the value of lv_obj_t *obj (in my case gauge1 or led1 etc)?
This behaviour is exhibited if I do the update via an lv_task or directly in my main loop, so I believe the tick timer is not the fault here as the object updates if I do everything in an ino file like so:
int g_val = 0;
lv_obj_t * gauge1;
void setup() {
while (!Serial && millis() < 5000);
Serial.begin(115200);
pinMode(4, OUTPUT);
tft.begin();
tft.setBitDepth(16);
tft.setRotation(1);
//tft.setTearingEffect(true);
tft.setFrameRate(78);
tft.setAddrWindow(0, 0, screenWidth - 1, screenHeight - 1);
if (!ts.begin(40)) {
Serial.println("Unable to start touchscreen.");
else {
Serial.println("Touchscreen started ok.");
digitalWrite(4, HIGH);
lv_disp_buf_init(&disp_buf, buf, NULL, LV_HOR_RES_MAX * LV_VER_RES_MAX/ 40 );
//lv_log_register_print_cb(my_print); /* register print function for debugging */
/*Initialize the display*/
lv_disp_drv_t disp_drv;
lv_disp_drv_init(&disp_drv);
disp_drv.buffer = &disp_buf;
lv_indev_drv_t indev_drv;
lv_indev_drv_init(&indev_drv); /*Descriptor of a input device driver*/
indev_drv.type = LV_INDEV_TYPE_POINTER; /*Touch pad is a pointer-like device*/
indev_drv.read_cb = my_touchpad_read; /*Set your driver function*/
lv_indev_drv_register(&indev_drv); /*Finally register the driver*/
Serial.println("tick.begin");
tick.begin(lv_tick_handler, LVGL_TICK_PERIOD * 1000); // Start ticker
static lv_color_t needle_colors[3];
needle_colors[0] = LV_COLOR_BLUE;
needle_colors[1] = LV_COLOR_ORANGE;
needle_colors[2] = LV_COLOR_PURPLE;
/*Create a gauge*/
gauge1 = lv_gauge_create(lv_scr_act(), NULL);
lv_gauge_set_needle_count(gauge1, 1, needle_colors);
lv_obj_set_size(gauge1, 200, 200);
lv_obj_align(gauge1, NULL, LV_ALIGN_CENTER, 0, 0);
/*Set the values*/
lv_gauge_set_value(gauge1, 0, 0);
const int loopDelay1 = 5; // Make a request every 5ms
unsigned long timeNow1 = 0;
const int loopDelay2 = 10; // Make a request every 10ms
unsigned long timeNow2 = 0;
void loop() {
if (millis() > timeNow1 + loopDelay1)
timeNow1 = millis();
if (millis() > timeNow2 + loopDelay2)
timeNow2 = millis();
g_val++;
lv_gauge_set_value(gauge1, 0, g_val);
if (g_val >=100){
g_val = 0;
Whereas in my actual app, I have all the LVGL object and UI rendering code in a separate .c file (its based off the lv printer demo) and I added a function in that .c file to update the gauge/labels and it is called from the main loop within the .ino file
So I suspect my object might be NULL as you suggested.
In this case the easiest solution is to use a global variable to store object references. Ensure you are not shadowing the variable (redeclaring it within a function) otherwise the global won’t get updated. I think Arduino IDE has a warning for that, but I don’t think they enable it by default.
This was the case… I was sure I had removed the variable declaration of all the labels and gauge from my startup function.
All is working now, and I must say, even smoother than it was before! Very amazed at the performance bump after this fix
Thought I’d share a video of the first live data test with LVGL handling the UI
https://youtu.be/wKEKcuaV_A8
I am positively surprised at the smoothness and speed of the UI! Very stoked!
Love it! The gauge animation when you open the page looks amazing!
WoW! Good job man!
