I disable the scrolling function of the container, and then drag the subcomponent of the container. Some events in the subcomponent that are not called by scrolling are triggered. How can I prevent these events from being triggered when dragging? When the container starts scrolling, some event functions will not be called
vs code
v8.0
void lv_screen_11(void)
lv_obj_clean(lv_scr_act());
lv_obj_t * scr = lv_obj_create(NULL);
lv_scr_load(scr);
c[0] = NULL;
c[0] = (struct con *)malloc(sizeof(struct con));
if (c[0] == NULL){return;}
memset(c[0], 0, sizeof(struct con));
c[0]->number=5;
c[0]->cont=lv_obj_create(lv_scr_act());
lv_obj_set_size(c[0]->cont, 680, 800);
lv_obj_align(c[0]->cont,LV_ALIGN_RIGHT_MID,0,0);
lv_obj_set_style_bg_color(c[0]->cont,lv_palette_darken(LV_PALETTE_GREY,2),0);
lv_obj_set_style_radius(c[0]->cont,0,0);
lv_obj_set_style_border_width(c[0]->cont,0,0);
lv_obj_set_style_pad_all(c[0]->cont,0,0);
lv_obj_clear_flag(c[0]->cont, LV_OBJ_FLAG_SCROLLABLE);
// lv_obj_add_flag(c[0]->cont,LV_OBJ_FLAG_SCROLLABLE);
// lv_obj_set_style_bg_opa(c[0]->cont, LV_OPA_0, LV_PART_SCROLLBAR | LV_STATE_DEFAULT);
// lv_obj_set_style_bg_opa(c[0]->cont, LV_OPA_0, LV_PART_SCROLLBAR | LV_STATE_SCROLLED);
c[1] = NULL;
c[1] = (struct con *)malloc(sizeof(struct con));
if (c[1] == NULL){return;}
memset(c[1], 0, sizeof(struct con));
c[0]->next=c[1];
c[1]->cont_1 = lv_obj_create(c[0]->cont);
c[1]->cont_2 = lv_obj_create(c[1]->cont_1);
lv_obj_set_size(c[1]->cont_1, 680, 200);
lv_obj_set_style_bg_color(c[1]->cont_1,lv_palette_darken(LV_PALETTE_GREY,2),0);
lv_obj_set_style_radius(c[1]->cont_1,0,0);
lv_obj_set_style_border_width(c[1]->cont_1,0,0);
// lv_obj_clear_flag(c[1]->cont_1,LV_OBJ_FLAG_SCROLLABLE);
lv_obj_align(c[1]->cont_1,LV_ALIGN_TOP_RIGHT,0,0);
lv_obj_set_style_pad_all(c[1]->cont_1,0,0);
lv_obj_add_event_cb(c[1]->cont_1, drag_event_handler, LV_EVENT_PRESSING, c[1]->cont_1); //
lv_obj_add_event_cb(c[1]->cont_1, drag_event_handler, LV_EVENT_RELEASED, c[1]->cont_1); //
lv_obj_t * dd;
dd = lv_dropdown_create(c[1]->cont_1);
lv_dropdown_set_options(dd,
"Normal\n"
"1 / 90\n"
"1 / 100\n"
"1 / 125\n"
"1 / 180\n"
"1 / 250\n"
"1 / 350\n"
"1 / 500\n"
"1 / 725\n"
"1 / 1000\n"
"1 / 1500\n"
"1 / 2000\n"
"1 / 3000\n"
"1 / 4000\n"
"1 / 6000\n"
"1 / 10K");
lv_dropdown_set_dir(dd, LV_DIR_BOTTOM);
lv_dropdown_set_symbol(dd, LV_SYMBOL_DOWN);
lv_obj_align(dd, LV_ALIGN_RIGHT_MID, 0, 0);
lv_obj_set_size(dd, 400,100);
lv_dropdown_set_selected(dd, 0);
add_dd_btn_style(dd);
lv_obj_add_event_cb(dd,add_dd_list_style,LV_EVENT_SHORT_CLICKED,dd);
lv_obj_add_event_cb(dd, drag_event_handler, LV_EVENT_PRESSING, c[1]->cont_1); //
lv_obj_add_event_cb(dd, drag_event_handler, LV_EVENT_RELEASED, c[1]->cont_1); //
lv_obj_set_size(c[1]->cont_2,680,100);
lv_obj_set_style_bg_color(c[1]->cont_2,lv_palette_lighten(LV_PALETTE_GREY,1),0);
lv_obj_align(c[1]->cont_2,LV_ALIGN_LEFT_MID,0,0);
lv_obj_set_style_radius(c[1]->cont_2,0,0);
lv_obj_set_style_border_width(c[1]->cont_2,0,0);
lv_obj_add_event_cb(c[1]->cont_2, drag_event_handler, LV_EVENT_PRESSING, c[1]->cont_1); //
lv_obj_add_event_cb(c[1]->cont_2, drag_event_handler, LV_EVENT_RELEASED, c[1]->cont_1); //
lv_obj_t* label;
label = lv_label_create(c[1]->cont_2); //
lv_label_set_text(label, "Stream Type"); //
lv_obj_set_style_text_font(label,&lv_font_montserrat_24,0);
lv_obj_set_style_text_color(label,lv_color_white(),0);
lv_obj_align(label,LV_ALIGN_LEFT_MID,0,0); //
static void drag_event_handler(lv_event_t* e)
lv_obj_t *con_1=lv_event_get_user_data(e);
// lv_obj_t * obj = lv_event_get_target(e);
lv_indev_t* indev = lv_indev_get_act();
lv_point_t vect;
lv_indev_get_vect(indev, &vect);
// lv_coord_t x = lv_obj_get_x(con_1) + vect.x;
lv_coord_t y = lv_obj_get_y(con_1) + vect.y;
// lv_obj_set_pos(obj, x, y);
// lv_obj_set_x(con_1,x);
lv_obj_set_y(con_1,y);
After dragging the drop-down list, the list will pop up. I want it not to pop up when I drag it
Can give me some advice? Thank in advance
