Drawing is really slow, switch page will cost 1.5s. How to speed up?
I touch tabs on the screen to switch page, flush_cb will be called several times, i print every call of flush_cb and its’ call time by clock() (time unit: ms).
In the below log we can see: there is nearly 1.4 second between two flush_cb, and i don’t know what lvgl is doing this time.
I (58340) ####: tabs clicked time: 56730
I (58480) ####: flush_cb start time: 56870
I (58480) EDDIY: flush_cb area rect: 34 x:1 y:31 w:68 h:85;
I (58480) ####: flush_cb end time: 56870
I (58490) ####: flush_cb start time: 56880
I (58490) EDDIY: flush_cb area rect: 35 x:1 y:116 w:68 h:85;
I (58500) ####: flush_cb end time: 56890
I (58510) ####: flush_cb start time: 56900
I (58510) EDDIY: flush_cb area rect: 36 x:1 y:201 w:68 h:85;
I (58520) ####: flush_cb end time: 56910
I (58530) ####: flush_cb start time: 56920
I (58530) EDDIY: flush_cb area rect: 37 x:1 y:286 w:68 h:85;
I (58530) ####: flush_cb end time: 56920
I (58540) ####: flush_cb start time: 56930
I (58540) EDDIY: flush_cb area rect: 38 x:1 y:371 w:68 h:85;
I (58550) ####: flush_cb end time: 56940
I (58560) ####: flush_cb start time: 56950
I (58560) EDDIY: flush_cb area rect: 39 x:1 y:672 w:68 h:85;
I (58570) ####: flush_cb end time: 56960
I (59920) ####: flush_cb start time: 58310
I (59920) EDDIY: flush_cb area rect: 40 x:70 y:30 w:954 h:728;
I (59920) ####: flush_cb end time: 58310
I have empty the flush_cb, set_px_cb code to avoid the influence from hardware.
ESP32
V8
Speed up drawing.
Change COLOR_DEPTH.
void app_main() {
int display_pixel_size = display_width * display_height;
lv_color_t* buf1 = (lv_color_t*)heap_caps_malloc(
display_pixel_size * sizeof(lv_color_t) / 2, MALLOC_CAP_SPIRAM);
assert(buf1 != NULL);
static lv_color_t* buf2 = NULL;
/* Initialize the working buffer depending on the selected display.
* NOTE: buf2 == NULL when using monochrome displays. */
lv_disp_draw_buf_init(&disp_buf, buf1, buf2, display_pixel_size);
lv_disp_drv_init(&disp_drv);
disp_drv.hor_res = display_width;
disp_drv.ver_res = display_height;
disp_drv.flush_cb = disp_driver_flush;
ESP_LOGI(TAG, "address of disp_drv: %p", &disp_drv);
/* When using a monochrome display we need to register the callbacks:
* - rounder_cb
* - set_px_cb */
#ifdef CONFIG_LV_TFT_DISPLAY_MONOCHROME
disp_drv.rounder_cb = disp_driver_rounder;
disp_drv.set_px_cb = disp_driver_set_px;
#elif CONFIG_LV_EPAPER_EPDIY_DISPLAY_CONTROLLER
/* Register an input device when enabled on the menuconfig */
#if CONFIG_LV_TOUCH_CONTROLLER != TOUCH_CONTROLLER_NONE
lv_indev_drv_t indev_drv;
indev_drv.read_cb = touch_driver_read;
/* Create and start a periodic timer interrupt to call lv_tick_inc */
const esp_timer_create_args_t periodic_timer_args = {
.callback = &lv_tick_task, .name = "lvgl_tick_periodic_timer"};
ESP_ERROR_CHECK(
esp_timer_create(&periodic_timer_args, &lvgl_tick_periodic_timer));
ESP_ERROR_CHECK(esp_timer_start_periodic(lvgl_tick_periodic_timer,
LV_TICK_PERIOD_MS * 1000));
// start_application
/* Force screen refresh */
lv_refr_now(NULL);
while (1) {
/* Delay 1 tick (assumes FreeRTOS tick is 10ms */
gui_task_queue_check();
// ESP_LOGI(TAG, "lv_task_handler, time: %ld.", clock());
/* Try to take the semaphore, call lvgl related function on success */
if (pdTRUE == xSemaphoreTake(xGuiSemaphore, portMAX_DELAY)) {
lv_task_handler();
xSemaphoreGive(xGuiSemaphore);
/* A task should NEVER return */
free(buf1);
#ifndef CONFIG_LV_TFT_DISPLAY_MONOCHROME
free(buf2);
vTaskDelete(NULL);
static void lv_tick_task(void* arg) {
(void)arg;
lv_tick_inc(LV_TICK_PERIOD_MS);
None.
Current hardware
- MCU:
ESP32(8M PSRAM & 16M Flash) - COLOR_DEPTH:
8, also tested1 - Display:
1024*758 - Screen: EPaper (Because i empty the
flush_cb, so this will not effect) - LVGL Version:
v8.2
