qualcomm msm8909
“version”: “6.1.1”,
- I want to make a FCT test page
I tried to keep initializing style and keep adding style, but the problem remained *
* INCLUDES
#include "./lv_examples/lv_examples.h"
#include "lv_ui_design.h"
#include "./lvgl/lvgl.h"
#include "common.h"
#include "module.h"
#include "func_map.h"
#include "mmi.h"
#include "utils.h"
#if LV_USE_DEMO_WIDGETS
* DEFINES
* TYPEDEFS
* STATIC PROTOTYPES
#if LV_USE_THEME_MATERIAL
static void color_chg_event_cb(lv_obj_t * sw, lv_event_t e);
#if LV_DEMO_WIDGETS_SLIDESHOW
static void tab_content_anim_create(lv_obj_t * parent);
static void tab_changer_task_cb(lv_task_t * task);
* banson add the definiton for ui design
#define LISTVIEW_W 600
#define LISTVIEW_H 1000
#define BUF_SIZE 1024
#define MCAMERA_PREVIEW_CMD "gst-launch-1.0 quectelmipisrc device=/dev/video0 ! 'video/x-raw, width=640, height=480,format=NV12' ! videoconvert! fbdevsink device=/dev/fb0"
#define FCAMERA_PREVIEW_CMD "gst-launch-1.0 quectelmipisrc device=/dev/video1 ! 'video/x-raw, width=640, height=480,format=NV12' ! videoconvert! fbdevsink device=/dev/fb0"
static lv_obj_t * list_t = NULL;
static char item_name[64] = {0};
static int item_num;
static pthread_t close_testwindow_tid = 0;
static pthread_t run_all_tid = 0;
static pthread_t camera_preview_tid = 0;
static pthread_t info_view_tid = 0;
static pthread_t monitor_key_tid = 0;
static pthread_mutex_t res_mutex = PTHREAD_MUTEX_INITIALIZER;
static pthread_mutex_t thread_mutex = PTHREAD_MUTEX_INITIALIZER;
static lv_obj_t* mainwindows=NULL;
static lv_obj_t* testwindows=NULL;
static lv_obj_t* btn_home = NULL;
static lv_obj_t* btn_menu = NULL;
static lv_obj_t* btn_back = NULL;
static lv_obj_t* btn_vol_up = NULL;
static lv_obj_t* btn_vol_down = NULL;
static lv_obj_t* label_result=NULL;
static lv_obj_t* btn_runall;
static lv_obj_t* btn_up;
static lv_obj_t* btn_down;
static lv_obj_t* btn_reset;
static lv_obj_t* btn_version;
static lv_obj_t* label;
static lv_obj_t* btn_img;
static bool btn_click=false; //This variable is to be placed into the callback twice
static int loop_state = 0;
static void lv_list_handler(lv_obj_t *obj, lv_event_t event);
static void lv_add_listview(lv_obj_t * parent);
static void count_result(lv_obj_t * parent)
int pass_num=0;
int fail_num=0;
int all_num=0;
char buf[128]={0};
if(label_result == NULL)
label_result = lv_label_create(parent, NULL);
lv_obj_set_width(label_result, 720);
lv_label_set_recolor(label_result, true);
lv_obj_align(label_result, NULL, LV_ALIGN_IN_TOP_LEFT, 30, 80);
lv_obj_set_style_local_text_font(label_result, LV_LABEL_PART_MAIN,
LV_STATE_DEFAULT, lv_theme_get_font_subtitle());
list < module_info * >::iterator iter;
for(iter = g_ordered_modules.begin(); iter != g_ordered_modules.end(); iter++)
module_info *mod = (module_info *) (*iter);
if(mod != NULL && (!mod->config_list[KEY_ENABLE].compare("1")) )
all_num++;
if(mod->result==SUCCESS)
pass_num++;
else if(mod->result==FAILED)
fail_num++;
sprintf(buf,"ALL=%d PASS=%d FAIL=%d NULL=%d",all_num,pass_num,fail_num,all_num-pass_num-fail_num);
lv_label_set_text(label_result, buf);
static void btn_pass_handler(lv_obj_t *obj, lv_event_t event)
// if(btn_click == false)
if(event == LV_EVENT_CLICKED)
if(obj != NULL) //This judgment is very important
//btn_click=true;
//lv_obj_t *test_win = lv_obj_get_parent(obj);
if(testwindows){
lv_obj_del(testwindows);
testwindows = NULL;
module_info *mod = NULL;
mod = get_module_by_name(item_name);
module_cleanup(mod);
process_exit(mod,SUCCESS);
if(strcmp(item_name,"CAMERA MAIN")==0 || strcmp(item_name,"CAMERA FRONT")==0){
pid_t pid = 0;
getPidByName(&pid, "gst-launch-1.0");
printf("kill the camera preview thread \n");
kill_proc(pid);
static void btn_fail_handler(lv_obj_t *obj, lv_event_t event)
//if(btn_click == false)
// btn_click=true;
if(testwindows){
testwindows = NULL;
process_exit(mod,FAILED);
pid_t pid = 0;
kill_proc(pid);
static void *run_all_thread(void *)
int cnt=0;
/* global item_name ? */
memset(item_name,0, sizeof(item_name));
strcpy(item_name,mod->module);
item_num=cnt;
lv_list_handler(NULL,LV_EVENT_CLICKED);
if(close_testwindow_tid) {
pthread_join(close_testwindow_tid, NULL);
usleep(1000 * 1000);
cnt++;
lv_btn_set_state(btn_runall, LV_BTN_STATE_RELEASED);
lv_btn_set_state(btn_reset, LV_BTN_STATE_RELEASED);
lv_btn_set_state(btn_version, LV_BTN_STATE_RELEASED);
static void btn_runall_handler(lv_obj_t *obj, lv_event_t event)
if(event == LV_EVENT_CLICKED){
lv_btn_set_state(btn_runall, LV_BTN_STATE_DISABLED);
lv_btn_set_state(btn_reset, LV_BTN_STATE_DISABLED);
lv_btn_set_state(btn_version, LV_BTN_STATE_DISABLED);
if(run_all_tid){
pthread_cancel(run_all_tid);
pthread_join(run_all_tid, NULL);
run_all_tid = 0;
/* bad idea to use pthread */
pthread_create(&run_all_tid, NULL, run_all_thread, NULL);
static void btn_up_handler(lv_obj_t *obj, lv_event_t event)
return lv_list_down(list_t);
static void btn_down_handler(lv_obj_t *obj, lv_event_t event)
return lv_list_up(list_t);
static void mbox_event_handler(lv_obj_t * obj, lv_event_t event)
if(event == LV_EVENT_VALUE_CHANGED)
lv_msgbox_stop_auto_close(obj);
static void btn_reset_handler(lv_obj_t *obj, lv_event_t event)
mod->result = ERR_UNKNOW;
mod->start_time = 0;
mod->duration = 0;
memset(mod->data, 0, sizeof(mod->data));
flush_result();
lv_list_clean(list_t);
usleep(1000 *200);
lv_add_listview(mainwindows);
static void btn_version_handler(lv_obj_t *obj, lv_event_t event)
/* static const char * btns[] ={"OK", ""};
lv_obj_t * mbox_version = lv_msgbox_create(mainwindows, NULL);
lv_msgbox_set_text(mbox_version, "A message box with one buttons.");
lv_msgbox_add_btns(mbox_version, btns);
lv_obj_set_width(mbox_version, 200);
lv_obj_set_event_cb(mbox_version, mbox_event_handler);
lv_obj_align(mbox_version, NULL, LV_ALIGN_CENTER, 0, 0); */
static void lv_add_mainwindow_button(lv_obj_t * parent)
btn_runall = lv_btn_create(parent, NULL);
lv_obj_set_size(btn_runall,200,100);
lv_obj_align(btn_runall, parent, LV_ALIGN_IN_BOTTOM_LEFT, 0, 0);//配置btn_runall在父类显示位置
lv_obj_set_event_cb(btn_runall, btn_runall_handler);
label = lv_label_create(btn_runall,NULL);
lv_label_set_text(label, "RUN_ALL");
btn_img = lv_img_create(btn_runall,NULL);
lv_img_set_src(btn_img,LV_SYMBOL_PLAY);
btn_up = lv_btn_create(parent, NULL);
lv_obj_set_size(btn_up,120,200);
lv_obj_align(btn_up, parent, LV_ALIGN_IN_RIGHT_MID, 0, -200);
lv_obj_set_event_cb(btn_up, btn_up_handler);
label = lv_label_create(btn_up,NULL);
lv_label_set_text(label, "UP");
btn_img = lv_img_create(btn_up,NULL);
lv_img_set_src(btn_img,LV_SYMBOL_UP);
btn_down = lv_btn_create(parent, NULL);
lv_obj_set_size(btn_down,120,200);
lv_obj_align(btn_down, parent, LV_ALIGN_IN_RIGHT_MID, 0, 200);
lv_obj_set_event_cb(btn_down, btn_down_handler);
label = lv_label_create(btn_down,NULL);
lv_label_set_text(label, "DOWN");
btn_img = lv_img_create(btn_down,NULL);
lv_img_set_src(btn_img,LV_SYMBOL_DOWN);
btn_reset = lv_btn_create(parent, NULL);
lv_obj_set_size(btn_reset,200,100);
lv_obj_align(btn_reset, parent, LV_ALIGN_IN_BOTTOM_MID, 0, 0);
lv_obj_set_event_cb(btn_reset, btn_reset_handler);
label = lv_label_create(btn_reset,NULL);
lv_label_set_text(label, "RESET");
btn_img = lv_img_create(btn_reset,NULL);
lv_img_set_src(btn_img,LV_SYMBOL_REFRESH);
btn_version = lv_btn_create(parent, NULL);
lv_obj_set_size(btn_version,200,100);
lv_obj_align(btn_version, parent, LV_ALIGN_IN_BOTTOM_RIGHT, 0, 0);
lv_obj_set_event_cb(btn_version, btn_version_handler);
label = lv_label_create(btn_version,NULL);
lv_label_set_text(label, "VERSION");
btn_img = lv_img_create(btn_version,NULL);
lv_img_set_src(btn_img,LV_SYMBOL_DIRECTORY);
static void *info_view_thread(void *)
// signal(SIGUSR1, signal_handler);
lv_obj_t * label_info;
label_info = lv_label_create(testwindows, NULL);
lv_obj_set_width(label_info, 720);
lv_label_set_recolor(label_info, true);
lv_obj_align(label_info, NULL, LV_ALIGN_CENTER, -200, -10);
loop_state = 1;
while(loop_state == 1)
if(strstr(label_view,"the light") !=NULL)
lv_label_set_text(label_info, label_view);
usleep(1000 *300);
loop_state = 0;
static void *monitor_key_thread(void *)
char label_tmp[20]={0};
//signal(SIGUSR1, signal_handler);
loop_state = 1;
if(label_view!=NULL && strlen(label_view) > 0)
snprintf(label_tmp, sizeof(label_tmp), "%s", label_view);
if(strcmp(label_tmp,"home")==0)
lv_btn_set_state(btn_home, LV_BTN_STATE_PRESSED);
if(strcmp(label_tmp,"menu")==0)
lv_btn_set_state(btn_menu, LV_BTN_STATE_PRESSED);
if(strcmp(label_tmp,"back")==0)
lv_btn_set_state(btn_back, LV_BTN_STATE_PRESSED);
if(strcmp(label_tmp,"vol_up")==0)
lv_btn_set_state(btn_vol_up, LV_BTN_STATE_PRESSED);
if(strcmp(label_tmp,"vol_down")==0)
lv_btn_set_state(btn_vol_down, LV_BTN_STATE_PRESSED);
memset(label_view, 0, sizeof(label_view));
} else
usleep(1000*200);
loop_state = 0;
static void lv_add_keytest(lv_obj_t * parent)
lv_obj_t * label;
lv_obj_t * btn_img;
btn_home = lv_btn_create(parent, NULL);
lv_btn_set_state(btn_home, LV_BTN_STATE_RELEASED);
lv_obj_set_size(btn_home,300,100);
lv_obj_align(btn_home, parent, LV_ALIGN_CENTER,0, -300);
label = lv_label_create(btn_home,NULL);
lv_label_set_text(label, "HOME");
btn_img = lv_img_create(btn_home,NULL);
lv_img_set_src(btn_img,LV_SYMBOL_HOME);
btn_vol_up = lv_btn_create(parent, NULL);
lv_btn_set_state(btn_vol_up, LV_BTN_STATE_RELEASED);
lv_obj_set_size(btn_vol_up,300,100);
lv_obj_align(btn_vol_up, parent, LV_ALIGN_CENTER, 0, -150);
label = lv_label_create(btn_vol_up,NULL);
lv_label_set_text(label, "VOL_UP");
btn_img = lv_img_create(btn_vol_up,NULL);
lv_img_set_src(btn_img,LV_SYMBOL_VOLUME_MAX);
btn_vol_down = lv_btn_create(parent, NULL);
lv_btn_set_state(btn_vol_down, LV_BTN_STATE_RELEASED);
lv_obj_set_size(btn_vol_down,300,100);
lv_obj_align(btn_vol_down, parent, LV_ALIGN_CENTER, 0, 0);
label = lv_label_create(btn_vol_down,NULL);
lv_label_set_text(label, "VOL_DOWN");
btn_img = lv_img_create(btn_vol_down,NULL);
lv_img_set_src(btn_img,LV_SYMBOL_VOLUME_MID);
btn_menu = lv_btn_create(parent, NULL);
lv_btn_set_state(btn_menu, LV_BTN_STATE_RELEASED);
lv_obj_set_size(btn_menu,300,100);
lv_obj_align(btn_menu, parent, LV_ALIGN_CENTER, 0, 150);
label = lv_label_create(btn_menu,NULL);
lv_label_set_text(label, "MENU");
btn_img = lv_img_create(btn_menu,NULL);
lv_img_set_src(btn_img,LV_SYMBOL_MINUS);
btn_back = lv_btn_create(parent, NULL);
lv_btn_set_state(btn_back, LV_BTN_STATE_RELEASED);
lv_obj_set_size(btn_back,300,100);
lv_obj_align(btn_back, parent, LV_ALIGN_CENTER, 0, 300);
label = lv_label_create(btn_back,NULL);
lv_label_set_text(label, "BACK");
btn_img = lv_img_create(btn_back,NULL);
lv_img_set_src(btn_img,LV_SYMBOL_BACKSPACE);
pthread_mutex_lock(&thread_mutex);
if(monitor_key_tid && loop_state == 1){
loop_state = 0;
if (0) {
pthread_cancel(monitor_key_tid);
pthread_join(monitor_key_tid, NULL);
usleep(10000);
pthread_mutex_unlock(&thread_mutex);
usleep(10000);
pthread_create(&monitor_key_tid, NULL, monitor_key_thread, NULL);
static void *camera_preview_thread(void *)
if(strcmp(item_name,"CAMERA MAIN")==0)
system(MCAMERA_PREVIEW_CMD);
else if(strcmp(item_name,"CAMERA FRONT")==0)
system(FCAMERA_PREVIEW_CMD);
static void lv_add_testwindow(lv_obj_t * parent)
lv_obj_t * btn_pass;
lv_obj_t * btn_fail;
lv_obj_t * label;
lv_obj_t * label_title;
lv_obj_t * label_img;
label_title = lv_label_create(parent, NULL);
lv_obj_set_width(label_title, 720);
lv_obj_align(label_title, NULL, LV_ALIGN_IN_TOP_LEFT,(LV_HOR_RES_MAX-strlen(item_name)*30)/2, 10);
lv_obj_set_style_local_text_font(label_title, LV_LABEL_PART_MAIN, LV_STATE_DEFAULT, lv_theme_get_font_title());
lv_label_set_text(label_title, item_name);
if(strcmp(item_name,"LIGHT SENSOR")==0) {
if(info_view_tid){
pthread_cancel(info_view_tid);
pthread_join(info_view_tid, NULL);
info_view_tid = 0;
pthread_create(&info_view_tid, NULL, info_view_thread, NULL);
if(strcmp(item_name,"KEY")==0) {
lv_add_keytest(parent);
if(strcmp(item_name,"CAMERA MAIN")==0 || strcmp(item_name,"CAMERA FRONT")==0) {
pid_t pid = 0;
kill_proc(pid);
if(camera_preview_tid){
pthread_cancel(camera_preview_tid);
pthread_join(camera_preview_tid, NULL);
usleep(20000);
pthread_create(&camera_preview_tid, NULL, camera_preview_thread, NULL);
btn_pass = lv_btn_create(parent, NULL);
lv_obj_set_size(btn_pass,360,150);
lv_obj_align(btn_pass, parent, LV_ALIGN_IN_BOTTOM_LEFT, 0, 0);
if(item_num < 9) //if the module auto return result,it does not set button callback
lv_obj_set_event_cb(btn_pass, btn_pass_handler);
label = lv_label_create(btn_pass,NULL);
label_img = lv_img_create(btn_pass,NULL);
lv_label_set_text(label, "PASS");
lv_img_set_src(label_img,LV_SYMBOL_OK);
btn_fail = lv_btn_create(parent, NULL);
lv_obj_set_size(btn_fail,360,150);
lv_obj_align(btn_fail, parent, LV_ALIGN_IN_BOTTOM_RIGHT, 0, 0);
lv_obj_set_event_cb(btn_fail, btn_fail_handler);
label = lv_label_create(btn_fail,NULL);
label_img = lv_img_create(btn_fail,NULL);
lv_label_set_text(label, "FAIL");
lv_img_set_src(label_img,LV_SYMBOL_WARNING);
static void *wait_closewindows_thread(void *)
int i = 0;
pid_t pid = -1;
lv_obj_t * label_result;
sem_wait(&g_sem_mod_complete); //wait for module test complete
usleep(1000);
kill_proc(pid);
// pthread_kill(camera_preview_tid,SIGUSR1);
usleep(1000 *200);
if(strcmp(item_name,"LIGHT SENSOR")==0 )
//pthread_kill(info_view_tid,SIGUSR1);
if(info_view_tid){
info_view_tid = 0;
usleep(1000 *200);
if(strcmp(item_name,"KEY")==0 )
// pthread_kill(monitor_key_tid,SIGUSR1);
loop_state = 0;
if (0) {
usleep(20000);
usleep(1000 *200);
if(item_num > 8) //auto return result,so the ui will display "detect" or "no detect"
if(is_return_result==1)
label_result = lv_label_create(testwindows, NULL);
lv_obj_align(label_result, NULL, LV_ALIGN_CENTER, 0, 0);
lv_label_set_text(label_result, strcat(item_name," = detect"));
else if(is_return_result==0)
lv_label_set_text(label_result, strcat(item_name," = no detect"));
usleep(1000 *1000);
usleep(1000 *100);
memset(item_name, 0, sizeof(item_name));
if(testwindows != NULL) {
testwindows = NULL;
usleep(1000 *100);
//lv_list_clean(list_t);
//btn_click=false;
// usleep(1000 *100);
count_result(mainwindows);
//pthread_exit(NULL);
int close_testwindow(char *item_name)
pid_t pid = -1;
if (item_name == NULL) {
ALOGI("[%s:%d] item_name is NULL", __func__, __LINE__);
return -1;
loop_state = 0;
if(strcmp(item_name,"CAMERA MAIN") == 0 ||
strcmp(item_name,"CAMERA FRONT") == 0) {
kill_proc(pid);
if(strcmp(item_name,"LIGHT SENSOR") == 0){
if(info_view_tid && loop_state == 1){
loop_state = 0;
info_view_tid = 0;
if(strcmp(item_name,"KEY") == 0) {
loop_state = 0;
testwindows = NULL;
return 0;
if(obj == NULL) //run all modules test
if (testwindows == NULL)
testwindows = lv_obj_create(lv_scr_act(),NULL);
lv_obj_set_size(testwindows, LV_HOR_RES_MAX, LV_VER_RES_MAX);
lv_add_testwindow(testwindows);
switch_module(mod);
if(close_testwindow_tid){
pthread_create(&close_testwindow_tid, NULL, wait_closewindows_thread, NULL);
return;
else //single module test
int cnt=0;
cnt++;
if(strstr(lv_list_get_btn_text(obj),mod->module)!=NULL) //find the module name
item_num=cnt-1;
switch_module(mod);
//pthread_create(&close_testwindow_tid, NULL, wait_closewindows_thread, NULL);
//ALOGI("[%s:%d] fulinux", __func__, __LINE__);
break;
if(list_t == NULL){
list_t = lv_list_create(parent, NULL);
else {
lv_obj_t * btn;
char buf[64] = {0};
int cnt=0;
lv_list_set_scroll_propagation(list_t, false);
lv_obj_set_size(list_t, LISTVIEW_W, LISTVIEW_H);
lv_obj_align(list_t, parent, LV_ALIGN_IN_LEFT_MID, 0, 20);
cnt++;
sprintf(buf,"%d %s",cnt,mod->module);
btn = lv_list_add_btn(list_t,LV_SYMBOL_OK,buf);
btn = lv_list_add_btn(list_t,LV_SYMBOL_WARNING,buf);
btn = lv_list_add_btn(list_t,NULL,buf);
lv_obj_set_event_cb(btn, lv_list_handler);
* GLOBAL FUNCTIONS
void lv_add_mainwindow(void)
mainwindows = lv_obj_create(lv_scr_act(), NULL);
lv_obj_set_size(mainwindows, LV_HOR_RES_MAX, LV_VER_RES_MAX);
LV_THEME_DEFAULT_INIT(lv_theme_get_color_primary(), lv_theme_get_color_primary(),
LV_THEME_MATERIAL_FLAG_DARK,
lv_theme_get_font_small(), lv_theme_get_font_normal(), lv_theme_get_font_subtitle(), lv_theme_get_font_title());
lv_add_mainwindow_button(mainwindows);
label_title = lv_label_create(mainwindows, NULL);
lv_obj_set_height(label_title,100);
lv_obj_set_style_local_text_font(label_title, LV_LABEL_PART_MAIN, LV_STATE_DEFAULT, lv_theme_get_font_subtitle());
lv_label_set_recolor(label_title, true);
lv_obj_align(label_title, NULL, LV_ALIGN_IN_TOP_LEFT, 40, 10);
lv_label_set_text(label_title, "QUECTEL SC20X FACTORY TEST");
