Hello everyone, i am developing a project using LVGL 9.2 and 4D-ESP32-GEN4-70-CLB from 4D-Systems. I am using a chart to visualize a signal. The chart is flickering very much.
i attached a video link.
9.2
avoid/minimize flickering
using one and/or two Buffers
reduced the LV_DEF_REFR_PERIOD to 10 and 20.
tried to use PSRAM, it minimized the flickering a little but its slowing down the other UI elements.
tried various sizes of draw_buf.
#include <lvgl.h>
#include "gfx4desp32_gen4_ESP32_70CT_CLB.h"
#define TFT_HOR_RES 800
#define TFT_VER_RES 480
#define DRAW_BUF_SIZE (TFT_HOR_RES * TFT_VER_RES / 10 * (LV_COLOR_DEPTH / 8))
#define PI 3.14159265
uint32_t draw_buf[DRAW_BUF_SIZE / 4];
uint32_t draw_buf2[DRAW_BUF_SIZE / 4];
lv_display_t* display1;
lv_obj_t* chart;
lv_timer_t* chart_timer = NULL;
static lv_style_t style_chart_dark;
static lv_style_t style_chart_light;
gfx4desp32_gen4_ESP32_70CT_CLB gfx = gfx4desp32_gen4_ESP32_70CT_CLB();
void my_disp_flush_cb(lv_display_t* disp, const lv_area_t* area, uint8_t* color_p) {
uint32_t numPixels = lv_area_get_size(area);
//lv_draw_sw_rgb565_swap(color_p, (area->x2 - area->x1 + 1) * (area->y2 - area->y1 + 1)); /// color swap, very important!!!!
gfx.SetGRAM(area->x1, area->y1, area->x2, area->y2);
gfx.pushColors((uint16_t*)color_p, numPixels);
lv_display_flush_ready(disp);
static uint32_t my_tick(void) {
return millis();
static void add_data1(lv_timer_t* t) {
static float phase = 0.0;
static float freq = 0.2;
lv_obj_t* chart = (lv_obj_t*)lv_timer_get_user_data(t);
lv_chart_series_t* ser = lv_chart_get_series_next(chart, NULL);
float raw = sin(2 * PI * phase);
int32_t value = (int32_t)(raw * 35 + 50); // Ergebnis in Bereich 15–85
lv_chart_set_next_value(chart, ser, value); // Skaliert auf sichtbare Werte
phase += freq;
if (phase >= 1.0) phase -= 1.0;
lv_chart_refresh(chart);
void createDisplay() {
display1 = lv_display_create(TFT_HOR_RES, TFT_VER_RES);
lv_display_set_buffers(display1, draw_buf, draw_buf2, DRAW_BUF_SIZE, LV_DISPLAY_RENDER_MODE_PARTIAL);
lv_display_set_default(display1);
lv_display_set_flush_cb(display1, my_disp_flush_cb);
lv_obj_set_style_bg_color(lv_screen_active(), lv_color_hex(0xff101010), LV_PART_MAIN | LV_STATE_DEFAULT);
void createChart() {
chart = lv_chart_create(lv_screen_active());
lv_chart_set_update_mode(chart, LV_CHART_UPDATE_MODE_SHIFT);
lv_obj_set_pos(chart, 10, 8);
lv_obj_set_size(chart, 780, 341);
lv_obj_set_style_bg_color(chart, lv_color_hex(0xff000000), LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_line_width(chart, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_size(chart, 0, 0, LV_PART_INDICATOR);
lv_obj_set_style_border_color(chart, lv_color_hex(0xff631212), LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_radius(chart, 120, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_border_width(chart, 5, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_shadow_opa(chart, 255, LV_PART_INDICATOR | LV_STATE_DEFAULT);
lv_obj_set_style_clip_corner(chart, true, LV_PART_MAIN | LV_STATE_DEFAULT);
uint32_t i;
lv_chart_set_point_count(chart, 60);
lv_chart_series_t* ser = lv_chart_add_series(chart, lv_palette_main(LV_PALETTE_RED), LV_CHART_AXIS_PRIMARY_Y);
for (i = 0; i < 80; i++) {
lv_chart_set_next_value(chart, ser, (int32_t)lv_rand(10, 90));
static void event_cb(lv_event_t* e) {
Serial.println("clicked");
LV_LOG_USER("Button %s clicked", lv_label_get_text(label));
void touch_read(lv_indev_t* indev, lv_indev_data_t* data) {
gfx.touch_Update();
bool touched = gfx.touch_GetPen();
if (touched == TOUCH_PRESSED) {
data->point.x = gfx.touch_GetX();
data->point.y = gfx.touch_GetY();
} else {
void createinputDevice() {
lv_indev_t* indev = lv_indev_create(); /* Create input device connected to Default Display. */
lv_indev_set_type(indev, LV_INDEV_TYPE_POINTER); /* Touch pad is a pointer-like device. */
lv_indev_set_read_cb(indev, touch_read);
void createRoller() {
lv_obj_t* roller = lv_roller_create(lv_screen_active());
lv_obj_set_pos(roller, 327, 357);
lv_obj_set_size(roller, 130, 110);
lv_roller_set_options(roller, "Option 1\nOption 2\nOption 3", LV_ROLLER_MODE_NORMAL);
lv_obj_set_style_bg_color(roller, lv_color_hex(0xffdd3636), LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_text_color(roller, lv_color_hex(0xffffffff), LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_border_opa(roller, 0, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_radius(roller, 20, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_bg_color(roller, lv_color_hex(0xff28252a), LV_PART_SELECTED | LV_STATE_DEFAULT);
lv_obj_add_event_cb(roller, roller_event, LV_EVENT_ALL, NULL);
static void roller_event(lv_event_t* e) {
lv_obj_t* obj = lv_event_get_target_obj(e);
char buf[32];
lv_roller_get_selected_str(obj, buf, sizeof(buf));
if (code == LV_EVENT_VALUE_CHANGED) {
if (chart_timer != NULL) {
lv_timer_del(chart_timer);
chart_timer = NULL;
if (strcmp(buf, "Option 1") == 0) {
chart_timer = lv_timer_create(add_data1, 200, chart);
Serial.println("Option 1");
} else if (strcmp(buf, "Option 2") == 0) {
Serial.println("Option 2");
} else if (strcmp(buf, "Option 3") == 0) {
Serial.println("Option 3");
void setup() {
Serial.begin(115200);
gfx.begin();
gfx.touch_Set(TOUCH_ENABLE);
createDisplay();
lv_tick_set_cb(my_tick);
createChart();
createinputDevice();
createRoller();
lv_obj_t* toggle = lv_switch_create(lv_screen_active());
lv_obj_align(toggle, LV_ALIGN_BOTTOM_LEFT, 0, 0);
lv_obj_set_size(toggle, 200, 100);
lv_obj_add_state(toggle, LV_STATE_CHECKED);
void loop() {
lv_timer_handler();
