How to solve black tft in simulator?
I decide to run PC simulator on windows but it took me a lot of time and it was failure due to different error . the error came from fbdev.c and some more if you want i will explain it here
so I installed a virtual ubuntu on vmware and i did compile project without error although it is showing a compelete black LCD
I followed a guideline posted in get started page and used a pre configured version that are recommended by site.
I did not change any thing in this zip file . in this file a demo create function is running in main file it can’t even run that black tft and program terminated just after it runs so i commented this line and ran “switch example” and “line example” instead but there is just a black tft screen
my C compiler is
i instaled build-essentials
gcc version 4.8.4 (Ubuntu 4.8.4-2ubuntu1~14.04.4)
my os is ubuntu 14.04 lts
my IDE is eclipse 12-2018
libsdl2-2.0-0
void lv_ex_line_1(void)
/Create an array for the points of the line/
static lv_point_t line_points = { {0, 0}, {240, 0}, {320, 10}, {180, 60}, {240, 10} };
    /*Create new style (thick dark blue)*/
    static lv_style_t style_line;
    lv_style_copy(&style_line, &lv_style_plain);
    style_line.line.color = LV_COLOR_MAKE(0x00, 0x3b, 0x75);
    style_line.line.width = 3;
    style_line.line.rounded = 1;
    /*Copy the previous line and apply the new style*/
    lv_obj_t * line1;
    line1 = lv_line_create(lv_scr_act(), NULL);
    lv_line_set_points(line1, line_points, 5);     /*Set the points*/
    lv_line_set_style(line1, LV_LINE_STYLE_MAIN, &style_line);
    lv_obj_align(line1, NULL, LV_ALIGN_CENTER, 0, 0);
I need this simulator to deisign my gui faster and to find out if some error in my actual hardware is either by low ram or not?
I edited this post to follow template . I could not find lvgl version in zip file
You need to fill out the template. Starting today, questions that ignore the template will not be answered.
Here’s a copy of the template if you need it:
Before posting
  • Be sure you have checked the relevant part of the documentation. We will not respond in detail to posts where you haven’t read the relevant documentation.
  • What MCU/Processor/Board are you using?
  • What compiler are you using?
  • What version of LittlevGL are you using?
  • What do you want to achieve?
  • What have you tried so far?
```c
your code here
I’ve just created a an Announcement about the Topic templates Please read it, and edit your first post according to the template.
Thank you!
@kisvegabor There is enough information in the first post now.
@AhmadBan Does it work if you clone a fresh pc_simulator from GitHub? Also, I don’t think anyone has tried running it in a VM before, so that could be part of the issue.
Actually, I’ve already tried it in a VM.
You should enable MONITOR_VIRTUAL_MACHINE in lv_drv_conf.h
thank you It worked
