I’m trying to create a library containing everything to run my TFT. This way my main code becomes easy to manage and I can swap displays by pointing to another library (I’m now using a simple lcd and would like to convert it to a tft).
If I run the full example in my “main.cpp” file it runs great. Now I’m creating a library (see code below). The only thing that doesn’t work as runnin the whole code in one cpp file is that I can’t link these: disp_drv.flush_cb = my_disp_flush;
I get this error:
lib\FabnetTFT\FabnetTFT.cpp: In member function ‘void FabnetTFT::start()’:
lib\FabnetTFT\FabnetTFT.cpp:36:23: error: cannot convert ‘FabnetTFT::my_disp_flush’ from type ‘void (FabnetTFT::)(lv_disp_drv_t*, const lv_area_t*, lv_color_t*) {aka void (FabnetTFT::)(_disp_drv_t*, const lv_area_t*, lv_color16_t*)}’ to type ‘void ()(_disp_drv_t, const lv_area_t*, lv_color_t*) {aka void ()(_disp_drv_t, const lv_area_t*, lv_color16_t*)}’
I’m using an ESP32 with Platformio
My own library where all my TFT functions are handled
Get it running without creating my own library, that works fine.
myTFT.h:
#ifndef _MYTFT_h
#define _MYTFT_h
#include <Adafruit_HX8357.h>
#include <Adafruit_STMPE610.h>
#include <lvgl.h>
#include <Ticker.h>
#ifdef ESP32
#define STMPE_IRQ 27
#define STMPE_CS 32
#define TFT_CS 15
#define TFT_DC 33
#define SD_CS 14
#define TFT_RST -1
class MyLCD
public:
MyLCD();
void start();
void loop();
private:
Ticker tick; /* timer for interrupt handler */
Adafruit_HX8357 tft = Adafruit_HX8357(TFT_CS, TFT_DC, TFT_RST);
Adafruit_STMPE610 touch = Adafruit_STMPE610(STMPE_CS);
lv_disp_buf_t disp_buf;
lv_color_t buf[LV_HOR_RES_MAX * 10];
uint8_t SCR_rotation = 1;
static void lv_tick_handler(void);
void my_disp_flush(lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p);
lv_obj_t *scr;
void lv_test_theme_1(lv_theme_t *th);
myTFT.cpp
#include "myTFT.h"
#include <Arduino.h>
#define LVGL_TICK_PERIOD 20
#define LV_THEME_MATERIAL_H 1
#define USE_LV_LOG 0
myTFT::myTFT()
myTFT::~myTFT()
void myTFT::start()
Serial.println(F("Starting LCD"));
tft.begin(); /* TFT init */
tft.setRotation(SCR_rotation); /* Landscape orientation */
lv_disp_buf_init(&disp_buf, buf, NULL, LV_HOR_RES_MAX * 10);
/*Initialize the display*/
lv_disp_drv_t disp_drv;
lv_disp_drv_init(&disp_drv);
disp_drv.hor_res = 480;
disp_drv.ver_res = 320;
//getting lost?? Here's the issue!!!!!
void myTFT::loop()
delay(5);
//******** Private Functions
/* Display flushing */
void myTFT::my_disp_flush(_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p)
uint16_t c;
tft.startWrite(); /* Start new TFT transaction */
tft.setAddrWindow(area->x1, area->y1, (area->x2 - area->x1 + 1), (area->y2 - area->y1 + 1)); /* set the working window */
for (int y = area->y1; y <= area->y2; y++)
for (int x = area->x1; x <= area->x2; x++)
c = color_p->full;
tft.writeColor(c, 1);
color_p++;
tft.endWrite(); /* terminate TFT transaction */
lv_disp_flush_ready(disp); /* tell lvgl that flushing is done */
