How to set the size of the tabview buttons
I try to set the size of the tabview buttons, but I recive a exception when I upload the code. How can I set the pad of the buttons or a smaller size? Thanks.
ESP32 with arduino Ide
7.8
Set the icons center in the buttons
Set the pad of the buttons.
lv_style_t style_TabView;
    lv_style_init(&style_TabView);
    lv_style_set_text_font(&style_TabView, LV_LABEL_PART_MAIN, &lv_font_montserrat_10);
    lv_style_set_pad_top(&style_TabView, LV_TABVIEW_PART_TAB_BTN, 5);
     // TAB
   tabview = lv_tabview_create(bg_middle, NULL);
   lv_obj_set_size(tabview, 320, 210);
   lv_tabview_set_btns_pos(tabview, LV_TABVIEW_TAB_POS_BOTTOM);
   lv_obj_add_style(tabview, LV_TABVIEW_PART_TAB_BTN, &style_TabView);
If I upload this code, the program reset each 2 seconds with the next exception:
10:20:40.164 → Core 1 register dump:
10:20:40.164 → PC : 0x4010be17 PS : 0x00060330 A0 : 0x800d7900 A1 : 0x3ffcc8f0
10:20:40.164 → A2 : 0x3ffcce0c A3 : 0x000000bd A4 : 0xffffffff A5 : 0xffffffff
10:20:40.164 → A6 : 0xffffffff A7 : 0x0000001b A8 : 0x000000bd A9 : 0x3ffcc8f0
10:20:40.164 → A10 : 0x00000001 A11 : 0x00000000 A12 : 0x00000000 A13 : 0x000000c0
10:20:40.164 → A14 : 0x3ffc29e0 A15 : 0x00000140 SAR : 0x00000001 EXCCAUSE: 0x0000001c
10:20:40.197 → EXCVADDR: 0x000000bd LBEG : 0x4010bd60 LEND : 0x4010bd6a LCOUNT : 0x00000000
10:20:40.197 →
10:20:40.197 → ELF file SHA256: 0000000000000000
10:20:40.197 →
10:20:40.197 → Backtrace: 0x4010be17:0x3ffcc8f0 0x400d78fd:0x3ffcc920 0x400d7e6f:0x3ffcc950 0x400d80fd:0x3ffcc970 0x400d5362:0x3ffcc9b0 0x400d5d10:0x3ffcc9e0 0x400e606a:0x3ffcca00 0x400e6407:0x3ffccc60 0x400d708e:0x3ffccc80 0x400d70f7:0x3ffcccd0 0x400d7130:0x3ffccd20 0x400d72dd:0x3ffccd40 0x400d76e6:0x3ffccdd0 0x400e07ef:0x3ffcce20 0x400e08d1:0x3ffcce40 0x400d19c9:0x3ffcce60 0x400f31cd:0x3ffcce80 0x400863fe:0x3ffccea0
10:20:40.232 →
10:20:40.232 → Rebooting…
10:20:40.232 → ets Jun 8 2016 00:22:57
10:20:40.232 →
10:20:40.232 → rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
10:20:40.232 → configsip: 0, SPIWP:0xee
10:20:40.232 → clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
10:20:40.267 → mode:DIO, clock div:1
10:20:40.267 → load:0x3fff0018,len:4
10:20:40.267 → load:0x3fff001c,len:1100
10:20:40.267 → load:0x40078000,len:10900
10:20:40.267 → load:0x40080400,len:6388
10:20:40.267 → entry 0x400806b4
And this is the decode with the esp exception decoder
PC: 0x4010be17: _lv_style_list_get_transition_style at C:\Users\alvar\Documents\Arduino\libraries\lvgl-master\src\lv_core\lv_style.c line 700
Decoding stack results
0x400d78fd: _lv_style_list_remove_style at C:\Users\alvar\Documents\Arduino\libraries\lvgl-master\src\lv_core\lv_style.c line 239
0x400d7e6f: _lv_style_get_ptr at C:\Users\alvar\Documents\Arduino\libraries\lvgl-master\src\lv_core\lv_style.c line 666
0x400d80fd: _lv_style_list_get_color at C:\Users\alvar\Documents\Arduino\libraries\lvgl-master\src\lv_core\lv_style.c line 870
0x400d5362: _lv_obj_get_style_int at C:\Users\alvar\Documents\Arduino\libraries\lvgl-master\src\lv_core\lv_obj.c line 2699
0x400d5d10: lv_obj_init_draw_rect_dsc at C:\Users\alvar\Documents\Arduino\libraries\lvgl-master\src\lv_core/lv_obj_style_dec.h line 122
0x400e606a: lv_btnmatrix_design at C:\Users\alvar\Documents\Arduino\libraries\lvgl-master\src\lv_widgets\lv_btnmatrix.c line 690
0x400e6407: create_axis_label_iter at C:\Users\alvar\Documents\Arduino\libraries\lvgl-master\src\lv_widgets\lv_chart.c line 1409
0x400d708e: lv_refr_obj at C:\Users\alvar\Documents\Arduino\libraries\lvgl-master\src\lv_core\lv_refr.c line 734
0x400d70f7: lv_refr_obj_and_children at C:\Users\alvar\Documents\Arduino\libraries\lvgl-master\src\lv_core\lv_refr.c line 656
0x400d7130: lv_refr_get_top_obj at C:\Users\alvar\Documents\Arduino\libraries\lvgl-master\src\lv_core\lv_refr.c line 596
0x400d72dd: _lv_inv_area at C:\Users\alvar\Documents\Arduino\libraries\lvgl-master\src\lv_core\lv_refr.c line 124
0x400d76e6: _lv_disp_refr_task at C:\Users\alvar\Documents\Arduino\libraries\lvgl-master\src\lv_core\lv_refr.c line 406
0x400e07ef: lv_task_handler at C:\Users\alvar\Documents\Arduino\libraries\lvgl-master\src\lv_misc\lv_task.c line 78
0x400e08d1: lv_task_handler at C:\Users\alvar\Documents\Arduino\libraries\lvgl-master\src\lv_misc\lv_task.c line 172
0x400d19c9: loop() at C:\Users\alvar\Documents\Arduino\CO2_Interfaz_SIN_WIFI/loop.ino line 6
0x400f31cd: _GLOBAL__sub_I_loopTaskHandle() at C:\Users\alvar\Documents\Arduino\hardware\espressif\esp32\cores\esp32/IPAddress.h line 94
0x400863fe: vPortTaskWrapper at /Users/ficeto/Desktop/ESP32/ESP32/esp-idf-public/components/freertos/port.c line 143
This is the view if I don’t add the style:
ApplicationFrameHost_UgqvSRpZRB
Only with this code:
  lv_style_init(&smallFont);
  lv_style_set_text_font( &smallFont, LV_STATE_DEFAULT, &lv_font_montserrat_10);
  // TAB
   lv_obj_add_style(tabview, LV_TABVIEW_PART_TAB_BTN, &smallFont);
    tab1 = lv_tabview_add_tab(tabview, LV_SYMBOL_LIST);
    lv_page_set_scroll_propagation(tab1, true);
    lv_page_set_scrlbar_mode(tab1, LV_SCRLBAR_MODE_OFF);
    lv_obj_set_width(tab1, 320);
    tab2 = lv_tabview_add_tab(tabview, LV_SYMBOL_LOOP);
    lv_page_set_scroll_propagation(tab2, true);
    lv_page_set_scrlbar_mode(tab2, LV_SCRLBAR_MODE_OFF);
    tab3 = lv_tabview_add_tab(tabview, LV_SYMBOL_SETTINGS);
    lv_page_set_scroll_propagation(tab3, true);
    lv_page_set_scrlbar_mode(tab3, LV_SCRLBAR_MODE_OFF);
    lv_obj_set_width(tab3, 320);
lv_style_t style_TabView; should be static or global to make it “live forever”. I assume now it’s a local variable and it goes out of the scope.
