How to set roller default
i create a roller with 6 item,but it select second item default.How to make roller start first item?
And there is a space area on roller and first item by default.
 lv_obj_clean(lv_scr_act());
    lv_obj_t* scr = lv_obj_create(NULL, NULL);
    lv_scr_load(scr);
    lv_obj_t* title = lv_label_create(scr, NULL);
    lv_label_set_text(title, "TEST");
    lv_obj_set_size(title, 320, 10);
    lv_obj_align(title, scr, LV_ALIGN_IN_TOP_MID, 0, 20);
    lv_obj_set_style_local_bg_color(title, LV_LABEL_PART_MAIN, LV_STATE_DEFAULT, LV_COLOR_ORANGE);
    lv_obj_set_style_local_bg_opa(title, LV_LABEL_PART_MAIN, LV_STATE_DEFAULT, LV_OPA_COVER);
    lv_obj_t* roller = lv_roller_create(scr, NULL);
    lv_roller_set_auto_fit(roller, false);
    lv_obj_set_size(roller, 310, 30);
    lv_roller_set_options(roller,
        "TEST one\n"
        "TEST two\n"
        "TEST three\n"
        "TEST four\n"
        "TEST five\n"
        "TEST six",
        LV_ROLLER_MODE_NORMAL);
    lv_roller_set_visible_row_count(roller, 4);
    lv_obj_align(roller, scr, LV_ALIGN_IN_TOP_MID, 0, 40);
    //lv_obj_set_event_cb(roller1, event_handler);
    lv_obj_t* back = lv_btn_create(scr, NULL);
    lv_obj_align(back, scr, LV_ALIGN_IN_BOTTOM_LEFT, 0, 0);
    //lv_obj_add_style(back, LV_BTN_PART_MAIN, &style_halo);
    lv_obj_set_style_local_value_str(back, LV_BTN_PART_MAIN, LV_STATE_DEFAULT, "Back");
    //lv_obj_set_event_cb(back, event_callback);
    lv_obj_t* Trans_type = lv_btn_create(scr, NULL);
    lv_obj_align(Trans_type, scr, LV_ALIGN_IN_BOTTOM_RIGHT, 0, 0);
    //lv_obj_add_style(Trans_type, LV_BTN_PART_MAIN, &style_halo);
    lv_obj_set_style_local_value_str(Trans_type, LV_BTN_PART_MAIN, LV_STATE_DEFAULT, "Confirm");
I think it’s the lv_roller_set_selected function:
The roller documentation:
https://docs.lvgl.io/latest/en/html/widgets/roller.html
if modify lv_roller_set_visible_row_count(roller, 2),it display correct,but roller height changed.
i want to fixed roller width and height,and set roller visible row count as 5.
does not work as expect.
     roller1 = lv_roller_create(om, NULL);
    //lv_obj_set_size(roller1,200,128);
    lv_obj_add_style(roller1, LV_ROLLER_PART_BG,&bg_style);
    lv_obj_add_style(roller1, LV_ROLLER_PART_SELECTED, &local_style);
    lv_roller_set_options(roller1,
                       LV_SYMBOL_AUDIO " 1\n"
                       LV_SYMBOL_VIDEO " 2\n"
        LV_SYMBOL_LIST " 3\n"
        LV_SYMBOL_GPS  " 4\n"
        LV_SYMBOL_WIFI " 5\n"
        LV_SYMBOL_BLUETOOTH " 6\n"
        LV_SYMBOL_POWER " 7\n"
        LV_SYMBOL_REFRESH " 8\n"
        LV_SYMBOL_VOLUME_MAX " 9\n"
        LV_SYMBOL_BELL" 10\n"
        LV_SYMBOL_CHARGE" 11\n"
                        "12",
        //LV_ROLLER_MODE_INIFINITE);
    lv_roller_set_anim_time(roller1, 50);
    lv_roller_set_fix_width(roller1,204);
    lv_roller_set_visible_row_count(roller1, 3);
    lv_obj_align(roller1, NULL, LV_ALIGN_CENTER, 0, 0);
when i modify as lv_roller_set_fix_width(roller,310);it seems display as expect.But you can see there is a space area as picture .How to decrease the White space?
Yes, in nomal mode, when you select item 0, there is a blank at the top. If you don’t want to see the blank, select LV_ROLLER_MODE_INIFINITE when creating ROLLER
ok,Thanks a lot.
Another question,when i press key1 or key1 on keyboad,how to get event from event_cb() to know which key is pressed?
sry,i don’t know the keypad is a input_dev or LVGL’s button ,if the first kind i think this link could be helpfull.
if the second one, you should give a call back fuction when you created the btn.
would you share a sample keyboad?
i mean when you press key on keyboad,you can get key event and which key pressed on event_cb()
if the samble run on real device,it iwll be better
you can check this demo:lv_demo_keypad_encoder();
Another question,when switch page,if textarea or button include the page,sometimes,the obj(textarea or button) will display on incorrect position then go back correct position a little time.
how to fixed the issue?
can you show me your code? because i don’t know how do you swtich the pages.
yes,i checked the sample.but i dont know how to get pressed key on keyboad in event_cb().only confirm key pressed,i can catch the event in event_cb()
plese check this:
static void ta_event_cb(lv_obj_t * ta, lv_event_t e)
    /*Create a virtual keyboard for the encoders*/
    lv_indev_t * indev = lv_indev_get_act();
    if(indev == NULL) return;
    lv_indev_type_t indev_type = lv_indev_get_type(indev);
    if(e == LV_EVENT_FOCUSED) {
        lv_textarea_set_cursor_hidden(ta, false);
        if(lv_group_get_editing(g)) {
            if(textinput_objs.kb == NULL) {
                textinput_objs.kb = lv_keyboard_create(lv_scr_act(), NULL);
                lv_group_add_obj(g, textinput_objs.kb);
                lv_obj_set_event_cb(textinput_objs.kb, kb_event_cb);
                lv_obj_set_height(tv, LV_VER_RES - lv_obj_get_height(textinput_objs.kb));
            lv_keyboard_set_textarea(textinput_objs.kb, ta);
            lv_group_focus_obj(textinput_objs.kb);
            lv_group_set_editing(g, true);
            lv_page_focus(t2, lv_textarea_get_label(ta), LV_ANIM_ON);
    else if(e == LV_EVENT_DEFOCUSED) {
        if(indev_type == LV_INDEV_TYPE_ENCODER) {
                lv_textarea_set_cursor_hidden(ta, true);
        } else {
static void kb_event_cb(lv_obj_t * kb, lv_event_t e)
    lv_keyboard_def_event_cb(kb, e);
    if(e == LV_EVENT_APPLY || e == LV_EVENT_CANCEL) {
        lv_group_focus_obj(lv_keyboard_get_textarea(kb));
        lv_obj_del(kb);
        textinput_objs.kb = NULL;
        lv_obj_set_height(tv, LV_VER_RES);
i think lv_obj_set_event_cb(textinput_objs.kb, kb_event_cb); is the key function;
here is first page code
static void DispLogo()
/Darken the button when pressed/
static lv_style_t style;
lv_style_init(&style);
lv_style_set_image_recolor_opa(&style, LV_STATE_PRESSED, LV_OPA_30);
lv_style_set_image_recolor(&style, LV_STATE_PRESSED, LV_COLOR_BLACK);
lv_style_set_text_color(&style, LV_STATE_DEFAULT, LV_COLOR_WHITE);
lv_obj_t * scr = lv_obj_create(NULL, NULL);
lv_scr_load(scr);
/*Create imgbtn*/
lv_obj_t* paymentbtn = lv_imgbtn_create(scr, NULL);
lv_imgbtn_set_src(paymentbtn, LV_BTN_STATE_RELEASED, &lv_logo_payment);
lv_imgbtn_set_src(paymentbtn, LV_BTN_STATE_PRESSED, &lv_logo_payment);
lv_imgbtn_set_checkable(paymentbtn, true);
lv_obj_add_style(paymentbtn, LV_IMGBTN_PART_MAIN, &style);
lv_obj_align(paymentbtn, scr, LV_ALIGN_IN_TOP_LEFT,20, 30);
//lv_obj_set_auto_realign();
lv_obj_t* Networkbtn = lv_imgbtn_create(scr, NULL);
lv_imgbtn_set_src(Networkbtn, LV_BTN_STATE_RELEASED, &lv_logo_network);
lv_imgbtn_set_src(Networkbtn, LV_BTN_STATE_PRESSED, &lv_logo_network);
lv_imgbtn_set_checkable(Networkbtn, true);
lv_obj_add_style(Networkbtn, LV_IMGBTN_PART_MAIN, &style);
lv_obj_align(Networkbtn, scr, LV_ALIGN_IN_TOP_LEFT,120, 30);
lv_obj_t* Downloadbtn = lv_imgbtn_create(scr, NULL);
lv_imgbtn_set_src(Downloadbtn, LV_BTN_STATE_RELEASED, &lv_logo_Download);
lv_imgbtn_set_src(Downloadbtn, LV_BTN_STATE_PRESSED, &lv_logo_Download);
lv_imgbtn_set_checkable(Downloadbtn, true);
lv_obj_add_style(Downloadbtn, LV_IMGBTN_PART_MAIN, &style);
lv_obj_align(Downloadbtn, scr, LV_ALIGN_IN_TOP_LEFT, 220, 30);
lv_obj_t* Testbtn = lv_imgbtn_create(scr, NULL);
lv_imgbtn_set_src(Testbtn, LV_BTN_STATE_RELEASED, &lv_logo_Test);
lv_imgbtn_set_src(Testbtn, LV_BTN_STATE_PRESSED, &lv_logo_Test);
lv_imgbtn_set_checkable(Testbtn, true);
lv_obj_add_style(Testbtn, LV_IMGBTN_PART_MAIN, &style);
lv_obj_align(Testbtn,scr, LV_ALIGN_IN_TOP_LEFT,20,130);
lv_obj_t* Historybtn = lv_imgbtn_create(scr, NULL);
lv_imgbtn_set_src(Historybtn, LV_BTN_STATE_RELEASED, &lv_logo_History);
lv_imgbtn_set_src(Historybtn, LV_BTN_STATE_PRESSED, &lv_logo_History);
lv_imgbtn_set_checkable(Historybtn, true);
lv_obj_add_style(Historybtn, LV_IMGBTN_PART_MAIN, &style);
lv_obj_align(Historybtn,scr, LV_ALIGN_IN_TOP_LEFT, 120, 130);
lv_obj_t* Infobtn = lv_imgbtn_create(scr, NULL);
lv_imgbtn_set_src(Infobtn, LV_BTN_STATE_RELEASED, &lv_logo_Info);
lv_imgbtn_set_src(Infobtn, LV_BTN_STATE_PRESSED, &lv_logo_Info);
lv_imgbtn_set_checkable(Infobtn, true);
lv_obj_add_style(Infobtn, LV_IMGBTN_PART_MAIN, &style);
lv_obj_align(Infobtn, scr, LV_ALIGN_IN_TOP_LEFT, 220, 130);
here is second page code:
static void DispInput()
lv_scr_load(scr);
lv_label_set_text(title, “PAYMENT”);
lv_obj_align(title,scr, LV_ALIGN_IN_TOP_MID, 0,30);
lv_obj_t* amt = lv_label_create(scr, NULL);
lv_label_set_text(amt, "AMOUNT:");
lv_obj_set_size(amt, 50, 10);
lv_obj_align(amt,scr, LV_ALIGN_IN_TOP_LEFT, 10, 50);
lv_obj_t* Cur = lv_label_create(scr, NULL);
lv_label_set_text(Cur, " $ ");
lv_obj_set_size(Cur, 50, 10);
lv_obj_align(Cur,scr, LV_ALIGN_IN_TOP_RIGHT, -20, 50);
lv_obj_t* input = lv_textarea_create(scr, NULL);
lv_obj_set_size(input, 320, 40);
lv_obj_align(input, scr, LV_ALIGN_IN_BOTTOM_RIGHT, 0, -80);
lv_textarea_set_text(input, "0.01");
lv_textarea_set_text_align(input,LV_LABEL_ALIGN_RIGHT);
lv_obj_set_state(input, LV_STATE_DEFAULT);
//lv_obj_set_event_cb(input, Input_handler);
static lv_style_t style_btn;
lv_style_init(&style_btn);
lv_style_set_transition_time(&style_btn, LV_STATE_PRESSED, 400);
lv_style_set_transition_time(&style_btn, LV_STATE_DEFAULT, 0);
lv_style_set_transition_delay(&style_btn, LV_STATE_DEFAULT, 200);
lv_style_set_outline_width(&style_btn, LV_STATE_DEFAULT, 0);
lv_style_set_outline_width(&style_btn, LV_STATE_PRESSED, 20);
lv_style_set_outline_opa(&style_btn, LV_STATE_DEFAULT, LV_OPA_COVER);
lv_style_set_outline_opa(&style_btn, LV_STATE_FOCUSED, LV_OPA_COVER);   /*Just to be sure, the theme might use it*/
lv_style_set_outline_opa(&style_btn, LV_STATE_PRESSED, LV_OPA_TRANSP);
lv_style_set_transition_prop_1(&style_btn, LV_STATE_DEFAULT, LV_STYLE_OUTLINE_OPA);
lv_style_set_transition_prop_2(&style_btn, LV_STATE_DEFAULT, LV_STYLE_OUTLINE_WIDTH);
lv_obj_add_style(back, LV_BTN_PART_MAIN, &style_btn);
//lv_obj_set_event_cb(back, Back_home_handle);
lv_obj_align(Trans_type,scr, LV_ALIGN_IN_BOTTOM_RIGHT, 0, 0);
lv_obj_add_style(Trans_type, LV_BTN_PART_MAIN, &style_btn);
lv_obj_set_style_local_value_str(Trans_type, LV_BTN_PART_MAIN, LV_STATE_DEFAULT, "Type");
//lv_obj_set_event_cb(back, Select_TransType_handle);
when i pressed confirm button on keyboad,will switch to page_2(DispInput),when i pressed Cancle Button on keyboad,will switch page_1(DispLogo)
when i test almost three times,i found textarea display on top of screen,wait almost 3ms,it go back correct position
i set tick as 20ms
