I have just recently started to work with LVGL and I use the Visual Studio 2019 simulator on windows to see results faster then porgramming the actual device. This problem I have does not cause the simulator to fail but the results are not what expected. On the actual devide I cannot compile it without error.
I am using a roller and I need a rather large font size so I am using the montserrat_48 for the selected font in the roller. I cannot find a way to increase the size of the fonts below and above the selected numbers. I understad that the background font size determines what that size of those fonts are. I could not find a way to overrwrite the background font just for the widget. The only way I could do it is by setting the #define LV_FONT_DEFAULT &lv_font_montserrat_30 in the lv_config.h file. Of course this messes up everything else so it is not a viable option.
I found a post for the V7.x as a solution which was like this but with a different font
lv_style_set_text_font(&style_sel, LV_STATE_DEFAULT, &lv_font_montserrat_30);
but this crashes the compiler so it does not work, it seems to be too many arguments.
I tried this with compile error:
static lv_style_t style_sel;
lv_style_init(&style_sel);
lv_style_set_text_font(&style_sel, &lv_font_montserrat_48);
This works in both the simulator and the hardware but not the results I want with all the styling seem to follow the default character which means the selected numbers are sitting in a smaller selection box starting to clip the top of the selected numbers:
Thank you for your help in advance
Andrew
