i want to select list by keypad,would you give same guidance.
static bool keypad_callback(lv_indev_drv_t * indev_drv, lv_indev_data_t * data)
u32 last_key = 0;
/*Get whether the a key is pressed and save the pressed key*/
Key_Num_t act_key = keypad_get_key();
if(act_key != KEY_NONE)
data->key=act_key;
/*Translate the keys to LVGL control characters according to your key definitions*/
switch(act_key)
case KEY_DOWN:
act_key = LV_KEY_DOWN;
break;
case KEY_UP:
act_key = LV_KEY_UP;
break;
case KEY_CANCEL:
act_key = LV_KEY_END;
break;
case KEY_CONFIRM:
act_key = LV_KEY_ENTER;
break;
case KEY_DELETE:
act_key = LV_KEY_DEL;
break;
case KEY_POWER:
act_key = LV_KEY_HOME;
break;
default:
break;
last_key = act_key;
data->key = last_key;
/*Return `false` because we are not buffering and no more data to read*/
return false;
#if LV_USE_LIST
static void Trans_Type_handler(lv_obj_t* obj, lv_event_t event)
u32 key=lark_kbd_read_buffer();
if (event == LV_EVENT_KEY)
//printf("Clicked: %s\n", lv_list_get_btn_text(obj));
TRACE(DBG_TRACE_LVL,"Clicked=%d\r\n",key);
void disp_Transtype_list(void)
g = lv_group_create();
/*Create a list*/
list = lv_list_create(lv_scr_act(), NULL);
lv_obj_set_size(list, 310, 200);
lv_obj_align(list, NULL, LV_ALIGN_CENTER, 0, 0);
/*Add buttons to the list*/
lv_obj_t* list_btn;
list_btn = lv_list_add_btn(list, NULL, "1.PAYMENT");
lv_obj_set_event_cb(list_btn, Trans_Type_handler);
list_btn = lv_list_add_btn(list, NULL, "2.REFUND");
list_btn = lv_list_add_btn(list, NULL, "3.INQUIRY");
list_btn = lv_list_add_btn(list, NULL, "4.BALANCE");
lv_group_add_obj(g, list_btn);
lv_indev_set_group(indev_keypad, g);
