How to select all textarea text upon focus
When a textarea receives focus, I want to select all of its text. But, when I do what I think should do to select the text, no text is selected – instead, the cursor is simply placed according to where the textarea was clicked (as if my focus event handler wasn’t called, but it is called according to Serial reports).
ESP32-2432S028R (cheap yellow display)
9.2.2
All text in a textarea is selected when it receives focus (this prepares to replace all existing text upon the next character input, similar to what happens when editing forms on most desktop GUIs and Android).
I have tried to programmatically select all text of the textarea in the textarea’s focus event handler (see code).
I’m unclear on where and when lv_textarea_set_text_selection should be called (once ever upon load, or every focus/defocus as I have here), but it doesn’t seem to matter for this problem.
void ta_Focused(lv_event_t* e) {
    Serial.println("ta_Focused");
    taSelected = (lv_obj_t*)lv_event_get_user_data(e);
    lv_textarea_set_text_selection(taSelected, true);
    length_t n = strlen(lv_textarea_get_text(taSelected));
    lv_obj_t* ta_label = lv_textarea_get_label(taSelected);
    lv_label_set_text_selection_start(ta_label, 0);
    lv_label_set_text_selection_end(ta_label, n);
    Serial.print("Selected 0 to "); Serial.println(n);
void ta_Defocused(lv_event_t* e) {
    Serial.println("ta_Defocused");
    lv_obj_t* ta = (lv_obj_t*)lv_event_get_user_data(e);
    lv_textarea_set_text_selection(ta, false);
void scrWheel_Loaded(lv_event_t* e) {
    lv_obj_add_event_cb(ui_taCompressed, ta_Focused, LV_EVENT_FOCUSED, ui_taCompressed);
    lv_obj_add_event_cb(ui_taCompressed, ta_Defocused, LV_EVENT_DEFOCUSED, ui_taCompressed);
    lv_obj_add_event_cb(ui_taExtended, ta_Focused, LV_EVENT_FOCUSED, ui_taExtended);
    lv_obj_add_event_cb(ui_taExtended, ta_Defocused, LV_EVENT_DEFOCUSED, ui_taExtended);
