I can’t figure out how to actually retrieve which key was pressed in an event callback.
Specifically, I’m using a roller callback, and I get the events like LV_EVENT_KEY and LV_EVENT_PRESSED.
However, the callback signature of the even callback system has no means of passing in the actual event data. How do I retrieve that?
I see in lv_event_send_func that the input device’s callback gets the data at indev_act->driver.feedback_cb, but I don’t quite see the use of that – isn’t it the indev that sent the key in the first place?
Simulator
github master branch cac6f92964f3cdb960612b21a7e7996af2a9e8ee
Get the key value so that I can pop out of a menu when a particular key is pressed.
looked through the code and I can’t find how I’m supposed to retrieve the actual key pressed value.
