Hello again,
I created a horizontal tileview consisting of objects, that fill each tile up. On one of these objects I created another tileview, but in the vertical direction. When I start the simulation, I can scroll through the horizontal tiles until I reach the tile with the vertical tileview. Then I can scroll in the horizontal direction, but I get trapped in the vertical tileview.
Is there a way I can address the horizontal scroll movement to the horizontal tileview when I’m inside the vertical tileview ?
VS2019-Simulator on Windows 10
latest
Continue to scroll horizontally out of the vertical tileview.
lv_obj_set_drag
lv_obj_set_drag_dir
lv_obj_set_drag_throw
lv_obj_set_drag_parent
lv_obj_set_parent_event
on both tileview (the vertical one) and it’s top tile.
//CREATE THE HORIZONTAL TILEVIEW
static lv_point_t valid_pos[] = { {0,0},{1,0},{2,0} }; //Horizontal
lv_obj_t * tileview = lv_tileview_create(lv_scr_act(), NULL);
lv_tileview_set_valid_positions(tileview, valid_pos, 3); //Horizontal
lv_obj_set_event_cb(tileview, my_event_cb);
lv_tileview_set_edge_flash(tileview, false);
lv_obj_t* tile1 = lv_obj_create(tileview, NULL); //Horizontal
lv_obj_set_size(tile1, LV_HOR_RES, LV_VER_RES);
lv_obj_set_style_local_bg_color(tile1, LV_OBJ_PART_MAIN, LV_STATE_DEFAULT, LV_COLOR_SILVER);
lv_tileview_add_element(tileview, tile1);
lv_obj_t* tile2 = lv_obj_create(tileview, NULL); //Horizontal
lv_obj_set_size(tile2, LV_HOR_RES, LV_VER_RES);
lv_obj_set_pos(tile2, LV_HOR_RES, 0);
lv_obj_set_style_local_bg_color(tile2, LV_OBJ_PART_MAIN, LV_STATE_DEFAULT, LV_COLOR_SILVER);
lv_obj_set_drag_parent(tile2, true);
lv_tileview_add_element(tileview, tile2);
lv_obj_t* tile3 = lv_obj_create(tileview, NULL); //Horizontal
lv_obj_set_size(tile3, LV_HOR_RES, LV_VER_RES);
lv_obj_set_pos(tile3, 2 * LV_HOR_RES, 0);
lv_obj_set_style_local_bg_color(tile3, LV_OBJ_PART_MAIN, LV_STATE_DEFAULT, LV_COLOR_SILVER);
lv_tileview_add_element(tileview, tile3);
//CREATE THE VERTICAL TILEVIEW
static lv_point_t valid_pos0[] = { {0,0},{0,1} }; //Vertikal
lv_obj_t* tileview0 = lv_tileview_create(tile1, NULL);
lv_obj_set_size(tileview0, LV_HOR_RES, LV_VER_RES);
lv_tileview_set_valid_positions(tileview0, valid_pos0, 2); //Vertikal
lv_tileview_set_edge_flash(tileview0, true);
lv_obj_t* tile10 = lv_obj_create(tileview0, NULL); //Vertikal
lv_obj_set_size(tile10, LV_HOR_RES, LV_VER_RES);
lv_obj_set_style_local_bg_color(tile10, LV_OBJ_PART_MAIN, LV_STATE_DEFAULT, LV_COLOR_BLACK);
lv_tileview_add_element(tileview0, tile10);
lv_obj_t* tile20 = lv_obj_create(tileview0, NULL); //Vertikal
lv_obj_set_size(tile20, LV_HOR_RES, LV_VER_RES);
lv_obj_set_pos(tile20, 0, LV_VER_RES);
lv_obj_set_style_local_bg_color(tile20, LV_OBJ_PART_MAIN, LV_STATE_DEFAULT, LV_COLOR_AQUA);
lv_tileview_add_element(tileview0, tile20);
