Linux with DRM backend.
v9.1
Rotate the whole screen.
lv_display_set_rotation(disp, LV_DISPLAY_ROTATION_270) has been called after lv_linux_drm_set_file(), but not working!
lv_display_t* disp = lv_linux_drm_create();
lv_linux_drm_set_file(disp, '/dev/dri/card0', -1);
lv_display_set_rotation(disp, LV_DISPLAY_ROTATION_270);
Did you ever get a resolution to this problem?
I too see a problem using the DRM driver and have a need to rotate my native portrait mode display → landscape.
Building with Yocto (Scarthgap) and using the latest (as of today) master GitHub - lvgl/lv_port_linux: LVGL configured to work with a standard Linux framebuffer
Native rotated 0
Native rotated 90 [Also the pointer gets all messed up]
I will try study up on /dev/dri/card1 driver and investigate.
/Robert
This is very similar to what I see. There doesn’t really seem to be support for rotation in the lvgl 9+ DRM stack. It’s not even clear to me why the screen gets altered at all when you apply the rotation.
Hej,
I spent a or two to investigate how to rotate stuff using the DRM interface.
Depending on HW and/or implementation it can be done. If the DRM plane (that you are using) has a “rotation” property, it is possible to rotate/reflect the screen.
This link describes the “rotation” property and as an added bonus also lists DRM drivers that supports it.
I’m using an imx8mp SoC [driver: imx-drm] and can therefore not rotate the screen using the DRM interface. I will either have to go for the SDL2 (full Linux stack/wayland/weston) interface or rotate everything in SW.
One more option I will check out is using GLE, but not sure if it is a viable option or not.
/Robert
