I would like to return align data of the object to the default value.
Is there any API function for resetting to the align-default?
Thank you.
As the upper description.
Why don’t you delete the object then recreate it ?
That would be quite inefficient with regards to performance.
If you are not using auto realign, you can just set the position of the object with lv_obj_set_pos
If you are using auto realign, you should disable it (lv_obj_set_auto_realign(obj, false)
)and then use the steps above.
ttxs1002004
Thank you for advice.
embeddedt
If you are using auto realign, you should disable it ( lv_obj_set_auto_realign(obj, false)
Thank you for the solution.
