Hi all,
I am trying to incorporate a table into my project and need to fit numerous lines on a 800x480 display. I am however finding I am unable to fit everything in the one page without scroll, even though there is ample room.
There seems to be some vertical padding being applied to the table cells somewhere that I can’t remove.
ESP32-S3 LCD Dev board with ESP-IDF.
8.4
I need to reduce the vertical padding to the point that all rows can be displayed on a single screen.
Adding the following lines, which is what I could find in my searches thus far:
lv_obj_set_style_pad_ver(table, 0, LV_PART_ITEMS);
lv_obj_set_style_pad_top(table, 0, LV_PART_ITEMS|LV_STATE_DEFAULT);
lv_obj_set_style_pad_bottom(table, 0, LV_PART_ITEMS|LV_STATE_DEFAULT);
static void draw_part_event_cb(lv_event_t * e)
/*If the cells are drawn...*/
if(dsc->part == LV_PART_ITEMS) {
uint32_t row = dsc->id / lv_table_get_col_cnt(obj);
uint32_t col = dsc->id - row * lv_table_get_col_cnt(obj);
if(col == 1 || col == 2 || col == 4 || col == 5) {
dsc->label_dsc->align = LV_TEXT_ALIGN_RIGHT;
void table_init(void) {
lvl_obj_t * table = lv_table_create(tableContainer);
lv_table_set_col_cnt(table, 6);
lv_table_set_row_cnt(table, 9);
lv_obj_center(table);
lv_obj_set_height(table, 480);
lv_obj_set_width(table, 800);
lv_obj_set_align(table, LV_ALIGN_CENTER);
lv_obj_set_style_pad_bottom(table, 2, LV_PART_ITEMS|LV_STATE_DEFAULT);
/*Add an event callback to to apply custom drawing*/
lv_obj_add_event_cb(table, draw_part_event_cb, LV_EVENT_DRAW_PART_BEGIN, NULL);
Thanks for reading ![]()
