I want to remove the glowing effect of LED object which makes a bit blurry look.
ESP32-S3
V8.3
I want a simple circle behaving like an LED and toggling the LED color on/off withouth any affect but simply showing provided HEX color codes. Cuz now I give OFF color as 0xd9d9d9 and i got darker (due to lv_led_set_brightness or too glowing shiny one. Same goes for my green color 0x00ff29 either too dark or too glowing!
I played with lv_led_on/off, lv_led_set_brightness in various combinations.
I couldn’t also find a simple circle shape; if I could, I would directly use circle for this purpose.
// example: it's too dark and therefore it's not MY given color code
||ui->screen_led_3 = lv_led_create(ui->screen_cont_1);|
||lv_led_set_brightness(ui->screen_led_3, 0);|
||lv_led_set_color(ui->screen_led_3, lv_color_hex(0xD9D9D9));|
||lv_obj_set_pos(ui->screen_led_3, 166, 184);|
||lv_obj_set_size(ui->screen_led_3, 10, 10);|
// Example: it's correct color but this time TOO glowing at the edges hence it doesn't work as we're required.
||lv_led_set_brightness(ui->screen_led_3, 255);|
below is the UI design that we want to achieve.
and below is what we got (shot photo from real display so quality is a bit bad; sorry)
