How to remove bottom-edge clipping in the Arc widget/design?
Hi everyone,
I am facing an issue with the arc design on the main screen. I have tried adjusting all possible settings, but the arc image is still getting clipped at the bottom ends (near the 0 and 160 marks).
Has anyone encountered this before, or is there a specific property/setting I am missing to prevent this cutoff?
static void create_speedo_gauge(lv_obj_t * parent)
/* 1. MASTER CONTAINER /
speedo_gauge_master = lv_obj_create(parent);
lv_obj_set_size(speedo_gauge_master, 268, 268);
lv_obj_set_pos(speedo_gauge_master, 490, 155);
lv_obj_set_style_bg_opa(speedo_gauge_master, 0, 0);
lv_obj_set_style_border_width(speedo_gauge_master, 0, 0);
lv_obj_set_style_pad_all(speedo_gauge_master, 0, 0);
lv_obj_clear_flag(speedo_gauge_master, LV_OBJ_FLAG_SCROLLABLE);
2. BACKGROUND IMAGE /
lv_obj_t * bg = lv_img_create(speedo_gauge_master);
lv_img_set_src(bg, &speedo);
lv_obj_align(bg, LV_ALIGN_CENTER, 0, 0);
3. THE ARC /
*** 1. Create Arc /
speedo_arc = lv_arc_create(speedo_gauge_master);
lv_obj_set_size(speedo_arc, 268, 268);
lv_obj_set_style_opa(speedo_arc, LV_OPA_TRANSP, LV_PART_KNOB);
lv_obj_align(speedo_arc, LV_ALIGN_CENTER, 0, 0);
lv_arc_set_rotation(speedo_arc, 135);
lv_arc_set_bg_angles(speedo_arc, 0, 270);
lv_arc_set_range(speedo_arc, 0, 160);//set range in ths case max is 140
2. Make background and knob transparent/hide /
lv_obj_set_style_arc_opa(speedo_arc, LV_OPA_TRANSP, LV_PART_MAIN);
* 3. CRITICAL: Set indicator width so LVGL allocates space to draw the image texture /
lv_obj_set_style_arc_width(speedo_arc, 70, LV_PART_INDICATOR); // Match your arc thickness (e.g., 20px)
* 4. Use Prerendered Image in place of ARC *************/
lv_obj_set_style_arc_image_src(speedo_arc, &ARC_BLUE, LV_PART_INDICATOR);
// Set arc endings to be flat (sharp cut) instead of rounded
lv_obj_set_style_arc_rounded(speedo_arc, false, LV_PART_INDICATOR);
// β€”> ADD THIS LINE HERE <β€”
lv_arc_set_value(speedo_arc, 0); // Force initial value to 0 on startup so it never shows halfway
4. SOC BACKGROUND IMAGE /
lv_obj_t * speedo_circle_bg = lv_img_create(speedo_gauge_master);
lv_img_set_src(speedo_circle_bg, &Soc_speedo);
lv_obj_align(speedo_circle_bg, LV_ALIGN_CENTER, -4, 15);
lv_obj_set_size(speedo_circle_bg,76,72);
Variable value label /
speedo_var_val = lv_label_create(speedo_circle_bg);
lv_obj_set_style_text_font(speedo_var_val, &lv_font_montserrat_48, 0);
lv_label_set_text(speedo_var_val,β€œ50”);
lv_obj_set_style_text_color(speedo_var_val, lv_color_white(), 0);
lv_obj_align(speedo_var_val, LV_ALIGN_CENTER, 0, 0);
Static SOC % label */
lv_obj_t * soc_const_val = lv_label_create(speedo_circle_bg);
lv_obj_set_style_text_font(soc_const_val, &lv_font_montserrat_16, 0);
lv_label_set_text(soc_const_val, β€œKm/h”);
lv_obj_set_style_text_color(soc_const_val, lv_color_white(), 0);
lv_obj_align(soc_const_val, LV_ALIGN_OUT_BOTTOM_MID, 58, 110);
  • MCU/MPU/Board: RH850
  • LVGL version: LVGL 9.6
@robertwilson its working now by increasing the size of arc and the base widgets thanks :+1:
Hi @Shri , If you have found a solution, could you please mark it as resolved?
