I’m developing a device based on ESP32, using an AMOLED display 454 x 454 x RGB 16bit. As the display has a MIPI interface, I’m using an SSD2805 chip to convert parallel data to MIPI signals. A bunch of wires, but all is working fine. I’m using two call backs: a rounder callback to correct addresses sent to the display, and a flush callback:
static void my_disp_flush(struct _disp_drv_t * disp_drv, const lv_area_t * area, lv_color_t * color_p)
SSD2805_dispFlush(area->x1, area->y1, area->x2, area->y2, (const uint16_t*)color_p);
lv_disp_flush_ready(disp_drv); /* Indicate you are ready with the flushing*/
Double buffering is used, trying sizes between 40 and 80 lines. I have a full screen refresh taking almost 300 ms, that’s quite a lot, especially after checking execution times.
With buffers of 40 lines, each call to my_disp_flush() takes 4.4 ms, with 19.2 ms between each call (12 in total).
With buffers of 80 lines, each call to my_disp_flush() takes 8 ms, with 34 ms between each call (6 in total).
Total time doesn’t improve much, and time between each call to my_disp_flush() is almost doubled when doubling the buffers size. Run time of the function is almost doubled when doubling the buffer size, as expected.
ESP32 NodeMCU / SSD2805 MIPI converted / MIPI AMOLED display
PlatformIO 5.1.1
SSD2805 / I2S libraries as in TechToys blog
7.9.1
I’d like to reduce the time between each call to the flush callback function to have a faster refresh rate. Is that possible? Where is the delay coming from?
Investigating lv_refr.c module trying to find where the long delay might come from, with no luck… Thank you for any suggestion!
See above my flush callback function.
