Hi, I’m facing issue with missing build-in icon (any SYMBOL_BATTERY_ ).
Sometimes instead of icon I see “?” symbol (see picture in the end of post).
In what cases “?” used and what does it mean?
I CANT reproduce this on PC simulator, but on MCU this happens in pretty stable maner.
Maybe someone have idea where to pay attention?
ESP32 with esp-idf ; LVGL 5.3
Displaying icons or understand reason why this may happens. Lack of memory? Miss position of some element?
I’m testing with different sizes of header, different alignment, different strings.
I noticed that this happens when I use cyryllic strings in header, with english text it always work.
Here is code, but again, on simulator this works and dont cause issue…
lv_obj_t * draw_battery_header(uint8_t bat_percent)
lv_obj_t * label_battery = lv_label_create(lv_scr_act(), NULL);
switch (bat_percent)
case 100:
lv_label_set_text(label_battery, SYMBOL_BATTERY_FULL);
break;
case 75:
lv_label_set_text(label_battery, SYMBOL_BATTERY_3);
break;
case 50:
lv_label_set_text(label_battery, SYMBOL_BATTERY_2);
break;
case 25:
lv_label_set_text(label_battery, SYMBOL_BATTERY_1);
break;
default:
lv_label_set_text(label_battery, SYMBOL_BATTERY_EMPTY);
break;
lv_obj_align(label_battery, NULL, LV_ALIGN_IN_TOP_LEFT, 9 , 5);
return label_battery;
lv_obj_t * scr_set_header(const char* lang_txt, const char* default_txt)
lv_obj_t * header = NULL;
lv_obj_t * battery = NULL;
battery = draw_battery_header(100);
header = lv_label_create(lv_scr_act(), NULL);
if (lang_txt != NULL) // specific lang name string exist
lv_label_set_text(header, lang_txt);
else // if no name found - load default english text
lv_label_set_text(header, default_txt);
lv_obj_align(header, battery, LV_ALIGN_OUT_RIGHT_MID, 2, 0);
lv_label_set_long_mode(header, LV_LABEL_LONG_ROLL);
lv_obj_set_size(header, 102, 20);
lv_label_set_anim_speed(header, 60);
return header;
static void screen_with_missing_battery()
static lv_obj_t * scr = NULL;
scr = lv_obj_create(NULL, NULL);
lv_scr_load(scr);
scr_set_header(NULL, "Результат"); // with English text alwys work fine
Here is how looks like on MCU screen
