I created a lvgl destop and some app on it . If running one of the app and quit it, how to fully release the memory the app had used? Just delete the object? how about the style ?
Best Regards!
James
STM32H7
V7.10
I just delete the object.
Hi, Miguel,
Thank you!
I have deleted the object yet. But how to deal with the style list? There seems have some memory allcated for it.
Best Rgegards,
James
lv_style_reset should deallocate all memory associated with the style.
Hi, embeddedt,
Thank you!
You means it must reset all the static style before the initial using? I do find out the memory leackage each time the app running and quitting. The most possibility would be the style ?
Best Regards,
James
Hi, embeddedt,
Further test shows that the memory leackage is still increasing by 30-50 byte each time the app page running and quitting, although I have reset all the style involved in the app page at the creating stage. The memory count is from lv_mem_monitor. What would be the reason?
Best Regards,
James
I am not entirely sure. I would suggest trying to isolate parts of your app and run them in isolation. Alternatively, if you can run it on a PC with LV_MEM_CUSTOM set to 1, I think Valgrind might have a feature for tracking memory leaks.
