How to put vertical sliders side by side in the lv_examples_menu_5
I am using lv_example_menu_5 as a base of my project. I have used lv_ grid to place a 3 by 3 button layout (lv_btn matrix does not provide the flexibility I need for each button placed in the section.
The example creates a section into which I pace two objects (grid and slider) and I want these side by side
lv_obj_t * sub_gimbal_page = lv_menu_page_create(menu, NULL);
lv_obj_set_style_pad_hor(sub_gimbal_page,
lv_obj_get_style_pad_left(lv_menu_get_main_header(menu), 0), 0);
lv_menu_separator_create(sub_gimbal_page);
section = lv_menu_section_create(sub_gimbal_page);
lv_gimbal_grid(section);
create_slider(section,LV_SYMBOL_SETTINGS, “Speed”, 0, 150, 100);
8.4
I assumed that I could use lv_obj_align_to(slider, parent, LV_ALIGN_TOP_RIGHT, 0, 0); to align the slider to the right of the parent i.e. section see code below
static lv_obj_t * create_slider(lv_obj_t * parent, const char * icon, const char * txt, int32_t min, int32_t
max,int32_t val)
lv_obj_t * obj = create_text(parent, icon, txt, LV_MENU_ITEM_BUILDER_VARIANT_2);
lv_obj_t * slider = lv_slider_create(obj);
lv_obj_set_size(slider, 20, 300);
lv_slider_set_range(slider, min, max);
lv_slider_set_value(slider, val, LV_ANIM_OFF);
if(icon == NULL) {
    lv_obj_add_flag(slider, LV_OBJ_FLAG_FLEX_IN_NEW_TRACK);
return obj;
The slider is shown below the grid. It appears that the align flags, although they compile do not work in a section created by lv_menu_section_create. I tried lv_menu_cont_create with the same result.
I also tried:
//section = lv_menu_section_create(sub_gimbal_page);
lv_obj_t * mycont = lv_cont_create(sub_gimbal_page, LV_LAYOUT_ROW_TOP)
but error “lv_cont_create’ was not declared in this scope” so I assume i t will not work if parent is a menu
Any ideas how to align two objects side by side in a menu page.
Thank you
PS because I do not understand the underling structure of LVGL I find it a very frustrating leaning curve and the documentation does explain what works with what FLAGS work with what widget.
try to use UI design tool like Square Line Studio or EEZ Studio.
Hi Thank, I will have a look at these options. But it appears to me that non of the alignment options work in a menu page. Even a single object will not align to center. Not sure if any one else has found this
Unfortunately Square Line Studio does not support the driver in the Waveshare ESP 32 3S LCD touch 4.3" display.
It is independent of the driver, as long as LvGL is working, it will work.
Check controllers tech youtube channel.
Unfortunately not so simple. With Arduino and Squareline use the TFT_esPI library. Should not be a problem as Waveshare provide a lvgL_port for the 4.3 touch which effectively replaces the TFT_esPI. Did not work at all.
Success using Expressif with a board that is very close to the 4.3 touch (ESP32-S3-LCD-EV-BOARD) , a simple label - it worked !, but I did have to create an Arduino project and copy the Squareline files to it and copy the screen.c contents to the project .ino file. I guess I need to work out how to #include the screens folder.
Just need to try a more complex layout.
I have limited experience with arduino ide.
I prefer to use more advanced IDE for the MCU.
