MCU goes to HardFault_Handler if I put buffer to external SDRAM and press any key on on screen keyboard. Other examples in lv_tutorials folder seem to work flawless.
STM32F746G-DISCO board
Put buffer into external SDRAM and use a full display sized buffer. May be double buffering
I made some modification on linker script.
I also tried to create large memory objects and read/write them in order to check the functionality of the FSMC module. FSMC initialized with supplied BSP package and it seems to be working without any problems.
/* In linker script */
/* Specify the memory areas */
MEMORY
RAM (xrw) : ORIGIN = 0x20000000, LENGTH = 320K
FLASH (rx) : ORIGIN = 0x8000000, LENGTH = 1024K
SDRAM (xrw) : ORIGIN = 0xC0000000, LENGTH = 8192K // I added this line
.HeapMemSection : {*(.HeapMemSection)} >SDRAM // heap memory section for ext. SDRAM
/*In tft.c file*/
#define EXT_BUFFER 1
#if EXT_BUFFER
#define _buf_size (TFT_HOR_RES * TFT_VER_RES)
static lv_color_t bufext_1[_buf_size] __attribute__((section(".HeapMemSection")));
#else
// this option works without any problems whatsoever
#define _buf_size (TFT_HOR_RES * 10)
static lv_color_t bufext_1[_buf_size]; // variable in internal RAM
static uintpixel_t my_fb[TFT_HOR_RES * TFT_VER_RES] __attribute__((section(".HeapMemSection")));
static lv_disp_buf_t disp_buf_1;
lv_disp_buf_init(&disp_buf_1, bufext_1, NULL, _buf_size); /*Initialize the display buffer*/
