I’m putting together a test to show an lvgl behaviour/issue when you perform a hook drawing on an arc indicator in meter object when LV_EVENT_DRAW_PART_END event happens.
So, I created a simple meter with no style, needle or ticks but a moving green arc indicator with a fixed width that moves around the meter with an animation. So far so good.
STM32H645XI-Custom board
8.3
Then I added an event to add a custom drawing on this arc by enabling LV_EVENT_DRAW_PART_END event. In the event callback, I drew another red arc with half-width the arc. (first half or second half or anywhere in between doesn’t matter). When I run the animation, it seems that not all essential drawing areas being refreshed (they are rendered I assumed)
At this moment I tried two quick fixes to see what’s next:
1- Invalidate the whole meter area / object at the end of the callback
2- Invalidate dirty area at the end of animation callback
3- Use full refresh for the whole screen
Only solution 2 and 3 worked but I wanted to know, what’s the proper way to tell lvgl to update those dirty areas in the callback? Why invalidate functions doesn’t work in this scenario?
static lv_obj_t * meter;
static lv_meter_scale_t * scale;
static lv_meter_indicator_t * arc;
static void _arc_cb(lv_event_t * e)
lv_meter_indicator_t * indic = (lv_meter_indicator_t *)dsc->sub_part_ptr;
lv_draw_arc_dsc_t arc_dsc;
lv_draw_arc_dsc_init(&arc_dsc);
arc_dsc.rounded = dsc->arc_dsc->rounded;
arc_dsc.start_angle = indic->scale->rotation;
arc_dsc.end_angle = indic->scale->rotation + 180;
arc_dsc.color = lv_color_hex(0xFF0000);
arc_dsc.width = 200;
uint16_t radius = dsc->radius;
int32_t start = indic->start_value;
int32_t end = indic->start_value + (indic->end_value - indic->start_value) / 2;
lv_draw_arc(dsc->draw_ctx, &arc_dsc, dsc->p1, radius, start + indic->scale->rotation,
end + indic->scale->rotation);
static void _anim_set_value(void * obj, int32_t v)
const int32_t length = 40;
int32_t start = v - length;
int32_t end = start + length;
if(v - length < 0)
start = 0;
end = v;
lv_meter_set_indicator_start_value(meter, arc, start);
lv_meter_set_indicator_end_value(meter, arc, end);
static void _animate(void)
lv_anim_t a;
lv_anim_init(&a);
lv_anim_set_exec_cb(&a, _anim_set_value);
lv_anim_set_values(&a, 0, 180);
lv_anim_set_repeat_count(&a, LV_ANIM_REPEAT_INFINITE);
lv_anim_set_repeat_delay(&a, 100);
lv_anim_set_playback_delay(&a, 100);
lv_anim_set_time(&a, 60000);
lv_anim_set_playback_time(&a, 500);
lv_anim_set_var(&a, arc);
lv_anim_start(&a);
void _arc_example(void)
meter = lv_meter_create(lv_scr_act());
lv_obj_remove_style(meter, NULL, LV_PART_INDICATOR);
lv_obj_set_size(meter, 300, 300);
scale = lv_meter_add_scale(meter);
lv_meter_set_scale_ticks(meter, scale, 0, 0, 0, lv_color_black());
arc = lv_meter_add_arc(meter, scale, 200, lv_color_hex(0x00FF00), 0);
lv_meter_set_scale_range(meter, scale, 0, 180, 180, 180);
lv_obj_add_event_cb(meter, _arc_cb, LV_EVENT_DRAW_PART_END, 0);
_animate();
With full-refresh enabled: (disp_drv.full_refresh = 1;)
Without full-refresh:
