I set an image as the background of an LVGL-screen. On the physical display is the same image, so everytime something is added to the background (LVGL-screen) it’s written to the display. The problem is that the screen “memorizes” the changes made even after a system-reset, when the image it’s referring to is renewed (copied from an SD-card). How to properly declare the LVGL-image to reset the changes?
STM32F439
8.3.8
Declare an image as screen-background and be able to start with a “clean slate” after a system-reset
Declared lv_img_dsc_t as const, static, globally, locally,…
#define DISP_WIDTH 1440
#define DISP_HEIGHT 900
#define (NUM_PIXELS DISP_WIDTH *DISP_HEIGHT)
static lv_img_dsc_t BB_Background_Image; // globally defined
static uint16_t u16_noBootDeviceLogo[NUM_PIXELS] // array to be displayed
static u8_bootscreen_lvglBackground[NUM_PIXELS*3] // array for the LVGL-screen-image
...initialize LVGL and copy data from SD-card to u16_noBootDeviceLogo
Then call the following functions
/* Transform uint16-RGB565-array to LVGL-compatible image an copy it */
void lvgl_create_bootscreen_backGround (void)
	uint32_t j = 0;
	// Turn boot-background to uint8 to be compatible with LVGL
	for (int i = 0; i < NUM_PIXELS*2; i=i+2)
		u8_bootscreen_lvglBackground[i] = u16_noBootDeviceLogo[j] & 0xFF; // Copy Low Byte
		u8_bootscreen_lvglBackground[i+1] = u16_noBootDeviceLogo[j] >> 8; // Copy High Byte
		j++;
	// Copy alpha channel to array
	memset(&u8_bootscreen_lvglBackground[NUM_PIXELS*2], 0xFF, NUM_PIXELS);
void lvgl_set_parent_backGround (void)
    // Set data of the LVGL-image-struct:
    BB_Background_Image.header.cf = LV_IMG_CF_RGB565A8;
    BB_Background_Image.header.always_zero = 0;
    BB_Background_Image.header.reserved = 0;
    BB_Background_Image.header.w = DISP_WIDTH;
    BB_Background_Image.header.h = DISP_HEIGHT;
    BB_Background_Image.data_size = NUM_PIXELS*3; // screen-pixels + alpha-channel
    BB_Background_Image.data = u8_bootscreen_lvglBackground;
    // Create new screen with image as background:
    parent_bootScreen_backGround = lv_obj_create(NULL);
    lv_obj_t * obj = lv_img_create(parent_bootScreen_backGround);
    lv_img_set_src(obj, &BB_Background_Image);
    // Load the new screen
    lv_scr_load(parent_bootScreen_backGround);
