How to properly apply styles to lv_roller and lv_list widgets
Hello
I need to implement two menu dialogs.
First one shall look like this:
This is list of menu items which I guess can be perfectly implemented using lv_list.
What I’ve got so far is this
Quick and dirty code that draws it is here:
uint8_t selectorViewCreate(view_t* ptr_view, const char* header, const char* items[], uint8_t items_count)
  ptr_view->ptr_data = malloc(sizeof(selector_view_data_t));
  selector_view_data_t* ptr_data = ptr_view->ptr_data;
  ptr_data->screen = lv_obj_create(NULL);
  lv_obj_set_style_bg_color(ptr_data->screen, lv_color_white(), LV_STATE_ANY | LV_PART_MAIN);
  ptr_data->list = lv_list_create(ptr_data->screen);
  lv_obj_set_size(ptr_data->list, 240, 200);
  lv_obj_center(ptr_data->list);
  lv_obj_set_style_border_width(ptr_data->list, 15, LV_STATE_ANY | LV_PART_MAIN);
  lv_obj_set_style_border_color(ptr_data->list, lv_color_white(), LV_STATE_ANY | LV_PART_MAIN);
  for (uint8_t i = 0; i < items_count; i++)
    lv_list_add_btn(ptr_data->list, NULL, items[i]);
    lv_obj_t* ptr_btn = lv_obj_get_child(ptr_data->list, i);
    lv_obj_set_style_bg_color(ptr_btn, lv_palette_main(LV_PALETTE_CYAN), LV_PART_MAIN | LV_STATE_PRESSED);
    lv_obj_set_style_radius(ptr_btn, 20, LV_PART_MAIN | LV_STATE_ANY);
  ptr_view->ptr_activate_fn = selectorViewActivate;
  ptr_view->ptr_deactivate_fn = NULL;
  ptr_view->ptr_render_fn = NULL;
  lv_obj_t *ptr_btn = lv_obj_get_child(ptr_data->list, 0);
  lv_obj_add_state(ptr_btn, LV_STATE_PRESSED);
  return 0;
Questions related to this are:
  1. How do I change border line width and color(marked by red arrow) ? I tried changing outline and border styles, but no effect.
  2. How do I hide horizontal lines (marked by green) between buttons (e.g. menu items) ?
  3. Why selected menu item (pressed button) does not have rounded corners (marked by violet lines) ? How do I fix that ?
Best regards and thanks in advance,
Vadym
  1. try to delete the LV_STATE_ANY, and it should work
  2. i assume the line is the border bottom of button, it’s defined in default style of button of a list, try this : lv_obj_set_style_border_width(btn, 0, LV_PART_MAIN);
  3. the rounded corner you see in top are the radius of LV_PART_MAIN of the list, try this
    lv_obj_set_style_radius(btn, 10, LV_PART_MAIN | LV_STATE_FOCUSED);
I think the problem is with LV_STATE_ANY
hope that helps
kind regards
Zebra
Thanks a lot, your advices were helpful
Hey. How did you expand the list area (marked by red arrow) ?
I have a small screen, so I need to move the icon to the left.
Also to the right, the entire width of the screen should be used
Tnx
You can change list size so it takes either entire screen or almost entire screen
If it can’t completely fill screen, try playing around with outlines and borders
