Hi Team,
Hope you all doing good
i have a small doubt with area widget.
i have created an custom view for list using area.
i created 3 labels inside the area widget and assigning text using arrays.
if i click on area i want to print their respective text.
For Example:
if i click on the first area i want to print devicename(“kitchen”) showing in that area. but printing last value “foyer”
attached event handler function also.
ARM
7
For Example:
char *array_devicename[]={"kitchen","bedroom","office","bathroom","foyer"};
char *array_type[]={"Dimmer","Switch","Thermostat","Smart plug","Camera"};
char *array_client[]={"Philips","Tp-Link","iotgizmo","Wemo","Nest"};
int length=sizeof(array_devicename)/sizeof(array_devicename[0]);
for(int i=0;i<length;i++){
// add an area
lv_obj_t * area = lv_obj_create(page, NULL);
lv_obj_set_size(area, 450, 150);
lv_obj_add_style(area, LV_OBJ_PART_MAIN, &style_box);
lv_obj_align(area, NULL, LV_ALIGN_OUT_BOTTOM_MID, 0, 10);
// adding stuff to area
//devicename
devicename = lv_label_create(area, NULL);
lv_label_set_recolor(devicename, true);
lv_label_set_text(devicename,array_devicename[i]);
lv_obj_align(devicename,NULL,LV_ALIGN_IN_TOP_LEFT,10,10);
//devicetype
lv_obj_t * devicetype = lv_label_create(area, NULL);
lv_label_set_recolor(devicetype, true);
lv_label_set_text(devicetype,array_type[i]);
lv_obj_align(devicetype,NULL,LV_ALIGN_IN_TOP_MID,0,10);
//client
lv_obj_t * client = lv_label_create(area, NULL);
lv_label_set_recolor(client, true);
lv_label_set_text(client,array_client[i]);
lv_obj_align(client,NULL,LV_ALIGN_IN_TOP_RIGHT,-10,10);
lv_obj_set_click(area, true);
lv_obj_set_drag_parent(area, true); // need this to scroll page properly
lv_obj_set_event_cb(area, page_event_handler);
static void page_event_handler(lv_obj_t * obj, lv_event_t event)
const char *clickdev=lv_label_get_text(devicename);
printf("Device ID: %s\n",clickdev);
Thanks in Advance.
