Does anyone know how to print degree of Celsius quickly?
Thanx
lv_label_set_text_fmt(lblInside, "Inside: #%s %s°c#", strColour, json_object_get_string(btemp));
Quick enough?
Which version? It does not produce ° sign on 7.11.
another copy of this:
It does not work for me either way:
lv_label_set_text_fmt(lbl_temp_mv_canvas, "%s %c C", pBoilerTemp->s, 0xB0); lv_label_set_text_fmt(lbl_temp_return_canvas, "%s °C", pReturnTemp->s); /* from line 1596 monts_26 */
Do not know why, I can see it in the font I use.
Thanks.
sorry, I did mean copy the degree symbol itself not the code:
If that doesnt work maybe @kisvegabor might be able to help?
Tried both. No go.
Maybe your source code isn’t encoded as UTF-8.
I don’t know what editor (IDE) you use.
But if you take notepad++ and open the source file, you can see the actual coding of your source file.
If it is ANSI the ° will not be seen on your display.
With notepad++ you can also easily convert the encoding from ANSI to UTF-8
Also you need to enable unicode-support.
I type on the keyboard ALT 0176
This meens, hold the ALT key down and type 0176 on the num keyboard
Strangely, it works in MCU, so the issue has been resolved.
- Don’t use With notepad++, How to use c code to convert the encoding from ANSI to UTF-8,thanks
Iconv
I’m using VSCode as my editor and a Mac as my host. For me, I was able to insert a degree symbol into a string simply by using Option-Shift-8.
–bob
