2、And, Tabs can still be switched by dragging left and right.
Unless I’m forgetting something, I don’t think there is a built-in way to disable a tabview. My suggested workaround would be a popup dialog with the control you are editing.
In v8 the disabled state will propagate to child objects, so I think implementing this will be much simpler.
The disabled state doesn’t propagate down to the buttons so using LV_STATE_DISABLED on the style won’t work. I think you would have to change the color manually - probably with a local style.
