I have a project that will switch between a lot of relatively large images. Because the spiflash-based FATFS is used on the hardware, the loading speed is estimated to be slower, which is not very friendly to interaction. So I want to preload the picture bin file in FATFS into PSRAM.
Windows simulator。
ESP32S3 N16R8
v8.3.0
preload images from fatfs
I tried it on a windows simulator:
FILE* f = fopen("E:\\**\\**.bin", "rb");
if (f == NULL)
printf("can't open file\n");
exit(1);
fseek(f, 0, SEEK_END);
size_t fSize = ftell(f);
fseek(f, 0, SEEK_SET);
char* buffer = (char*)malloc(sizeof(char) * fSize);
if (buffer == NULL)
printf("can't malloc buffer\n");
exit(1);
size_t result = fread(buffer, 1, fSize, f);
if (result != fSize)
printf("can't load data\n");
exit(1);
lv_img_dsc_t* img_dsc = (lv_img_dsc_t*)buffer;
lv_obj_t* img = lv_img_create(lv_scr_act());
lv_obj_align(img, LV_ALIGN_CENTER, 0, 0);
lv_img_set_src(img, img_dsc);
But the picture is not displayed. Through breakpoint debugging, I found that img_dsc->header reads the width and height of the picture correctly, but the value of img_dsc->data_size is 0, and img_dsc->data points to NULL
As shown above
